Topic: Arduino + Servo Help (Read 2138 times) previous topic - next topic
zoomkat
Quote
I would also like to add upon using the read() function of the Servo library, it just constantly reports 1 (even if i manually change the position by hand)
Quote
Anyway this setup isn't working for me, as the servo isn't working. Is this because the servo I am using is busted from me trying to use it on 5V when it is recommended for 4.8V?
You can strip the gears in a servo by twisting on the servo horn. Probably too late.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
E3po
Is it possible the servo is bad or connected improperly? (The positive voltage switched with the variable lead)  I have also purchased a DOA servo with a cold solder joint, that when re flowed, worked fine.
-E
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
