Topic: Store into multiple Variables from SD card (Read 525 times) previous topic - next topic
1o2o3o
I want to log distances on a robot and then compare them later, there are 4 sensors, so 4 sets of data to log.
i know its possible to write/print the data to the SD card using
Code: [Select]
    Data_logger.print(Distance_1, 2);
    Data_logger.print("      ");
    Data_logger.print(Distance_2, 2);
    Data_logger.print(Distance_3, 2);
    Data_logger.print(Distance_4, 2);
which will give me a single line of 4 numbers, each time the code is called.
is there a way to reverse that?
the data file will have content such as
line 1: distance1 distance2 distance3 distance4
line 2: distance1 distance2 distance3 distance4
line 3: distance1 distance2 distance3 distance4
and each iteration it stores line 1: distance1 in variable 1, 2 in 2 and so on, then it does line 2 then line 3!
PaulS
Quote
Yes. Read each character from the file. If the character is not a carriage return, store the character in the next position in an array, and increment the index.
If the character IS the carriage return, store a NULL in the next position in the array, and then use strtok() and atoi() or atof() to convert each token to an int or a float. Then, reset the index to 0 and put a NULL in the 0th position of the array.
1o2o3o
okay that sounds like a good solution!
but wont that save all values in one row into one variable? unless i have a statement that checks if the character is a " " or something, then it can convert the saves characters into an int, then continue until a carriage return. increase the index for the final saved ints and repeat for the whole file.
but how do i check each character individually? this method does take time though?
so far my knowledge is limited to "data.read(distance.txt)"
thanks a bunch
adwsystems
What are you using (post code) that isn't reading from the SD card one character (byte) at time?
So on the premise your program is reading one character at a time. If the character is not a space then add to a char[]. If the new character is a space then convert the char[] to the number value (atoi or atof) and store in the corresponding variable (a counter and switch statement could help with this if the variables are not an array).
1o2o3o
my bad, i just didnt understand how the SD card read worked, i just need it to read values and store them with a counter to split them into variables.
i have 4 variables that represent the data (distance values) that change a few times a second, so i created a 2D array to store the values. it reads the char in the sd card, saves them to an array, converts them to an int when a " " is reached. then it increases the counter and resets the array counter. at a counter of 4, it resets back to 0 and starts all over again for the next set of data.
thanks for the help!
