Loading...
Pages: [1]   Go Down
Author Topic: What is a servo controller needed for?  (Read 440 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I would like to play with servos. On all examples I have seen, the servo is connected directly to the arduino. But in many online stores they sell servo controllers as well.
What are these used for when a servo can be connected directly?
Thanks,
Martin
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
They're used when you need to connect more servos than an Arduino alone can control, or when you need the Arduino pins for something else.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Newbie
Arduino rocks
View Profile
So you mean if I need eg. 3 servos I need 3 pins, but using a servo controller I only use 1 pin?  So the arduino communicates serially with the controller?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Probably yes.
Never used one myself.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Sometime controller are used just to off load the task from the arduino sketch, freeing up arduino resources like timers, etc. Also many of the servo controllers have added functions and features not provided by the arduino servo library. In most cases the arduino alone is fine for controlling a couple of servos, depending on what other stuff you need to perform in your application.
Lefty
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Ok thanks. For my simple project a standalone servo is fine then.
Logged
Pages: [1]   Go Up
Print
Jump to:
