Topic: interfacing to max127 and i2c (Read 6774 times) previous topic - next topic
BrainBooster
Hi all,
i've built a simple adc addon board for arduino that adds 8 12 bit analog input channels, but it talks (or it should) with the i2c protocol :( and i don't know where to start from...
the ic i've used is the max127 and this is the http://datasheets.maxim-ic.com/en/ds/MAX127-MAX128B.pdf datasheet
I didn't found examples on that  ic and arduino, so now i'm asking your help.
I'm looking for some bare sample code to start from, any can help?
robtillaart
no Arduino code but this code should get you started.
From - http://pic-c.ccsinfo.com/forum/viewtopic.php?t=18886 - by gyork: Sun Apr 04, 2004 7:30 pm
Code: [Select]
void main() {
int16 atod,result;
int8 result1,result2,i;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_spi(FALSE);
setup_psp(PSP_DISABLED);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
printf("initiating max128\r\n");
//setup i2c
output_float(PIN_C3);
output_float(PIN_C4);
while (1){
//setup max128 to read channel 0
i2c_start();
i2c_write(0b01010000); //channel 0 0 to 4096 mV
i2c_write(0xF8); // send configuration bit
i2c_stop(); // start conversion
//read result from max128
i2c_start();
i2c_write(0b01010001); // send address to chip to begin read
result1 = i2c_read(); // get high byte of 12bit result
result2 = i2c_read(0);
i2c_stop(); // get low nibble of 12bit result
//convert to 16bit result
result = result1;
result = (result << 4 )+ (result2 >> 4); // combine into 16 bit result first four bits are 0s
printf("%ld\r\n",result); //debug
delay_ms(250);
Clear there is the initialization to start conversion and the read phase - In Arduinish this would become something like :
Code: [Select]
uint8_t deviceAddress = 0x50;
// START CONVERSION
Wire.beginTransmission(deviceAddress);
Wire.send(0xF8);
Wire.endTransmission();
// READ RESULT
Wire.requestFrom(deviceaddress, 2);
int result = 0;
for (int c = 0; c < 2; c++ )
if (Wire.available()) result = result * 256 + Wire.receive();
Maybe best to write a small class that accepts the deviceAddress in the constructor and provides a read() funtion that has the channel as parameter. That allows multiple MAX128 's in one sketch or to add functionality within the class, e.g. an array of prev values, a smoothRead() - etc
Succes,
Rob
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
BrainBooster
Thank you Rob for your answer,
actually i'm using this code to read the first channel of the adc but i'm only receive zeroes...
Code: [Select]
int deviceAddress = 0x50;
#include <Wire.h>
  Wire.begin();
Wire.send(0x88);
Wire.requestFrom(deviceAddress, 2);
int result = 0;
Serial.println(result);
at the moment this is not working, and i can't figure why...
robtillaart
I have no max127 so I cannot test the code.
Things I notice:
- you use an int for deviceAddress where the library expects an uint8_t. that should not cause any problem.
- you send control byte 0x88 = B 1000 1000  (lookup in PDF)
START = 1
SEL (210) = 000 => channel 0
RNG = 1
BIP = 0  => 0..10 Volt => full range
PD = 00 => normal mode
Seems all OK,
Best thing to do is check the return values of the Wire functions:
int x = Wire.beginTransmission(deviceAddress);
Serial.println(x);
etc to see if the handshake somewhere is not acknowledged.
Please post the results.
Rob Tillaart
BrainBooster
#4
Mar 27, 2011, 06:27 pm Last Edit: Mar 27, 2011, 06:38 pm by BrainBooster Reason: 1
i've changed the code this way
Code: [Select]
char c;
#include <Wire.h>
  Wire.begin();
// Read channel 0
Wire.send(0x88);
// READ RESULT
int result = 0;
while (Wire.available()) {
    c = Wire.receive();
    if (c != 0) {
      Serial.print(c);
this doesn't work too :(
if i insert the debug line you suggest i get this error:"master_reader.cpp: In function 'void loop()':
master_reader:15: error: void value not ignored as it ought to be"
I can scan and find the adc with i2c scanner, but it says address is 40! even more confused....
http://todbot.com/blog/2009/11/29/i2cscanner-pde-arduino-as-i2c-bus-scanner/
robtillaart
0x40 is not according spec. Spec might be woring ?
Did you try using address 0x40?
Have you connected the three address lines to Ground - so they are effectively zero? just checking:)
Rob Tillaart
BrainBooster
yes, and 0x40 doesn't work too...
A0 A1 and A2 are connected to ground , i've doublechecked them..
i don't know what to think to... :smiley-fat:
robtillaart
OK, try this ...
Code: [Select]
#include <Wire.h>
  Wire.begin();
  int x = 0;
  Serial.print("begin : "); Serial.println(x);
  x = Wire.send(0x88);
  Serial.print("send: "); Serial.println(x);
  x = Wire.endTransmission();
  Serial.print("end: "); Serial.println(x);
  x = Wire.requestFrom(deviceAddress, 2);
  Serial.print("req: "); Serial.println(x);
  int result = 0;
  while (Wire.available < 2)  // wait for 2 bytes
    Serial.print(".");
    delay(1);
  for (int c = 0; c < 2; c++)
  delay(10000);
Rob Tillaart
BrainBooster
doesn't compile...
it gives me the error i said before
robtillaart
I did not test the previous code, sorry; This one does compile under 21 (win7)
What are the results?
Code: [Select]
#include <Wire.h>
  Wire.begin();
  Wire.send(0x88);
  int x = 0;
  int result = 0;
  while (Wire.available() < 2)  // wait for 2 bytes
    Serial.print(".");
    delay(1);
  delay(10000);
Rob Tillaart
BrainBooster
serialmonitor  says:
........................................end:2
req:0
what does it mean?
robtillaart
So endTransmission returns 2    -  check the library what it means ......
Code: [Select]
uint8_t TwoWire::endTransmission(void)
  // transmit buffer (blocking)
  int8_t ret = twi_writeTo(txAddress, txBuffer, txBufferLength, 1);
  // reset tx buffer iterator vars
  txBufferIndex = 0;
  txBufferLength = 0;
  // indicate that we are done transmitting
  transmitting = 0;
  return ret;
Code: [Select]
* Function twi_writeTo
* Desc     attempts to become twi bus master and write a
*          series of bytes to a device on the bus
* Input    address: 7bit i2c device address
*          data: pointer to byte array
*          length: number of bytes in array
*          wait: boolean indicating to wait for write or not
* Output   0 .. success
*          1 .. length to long for buffer
*          [color=red]2 .. address send, NACK received[/color]
*          3 .. data send, NACK received
*          4 .. other twi error (lost bus arbitration, bus error, ..)
So it gets a NACK on the address.
NOw try the same with address 0x40 that you found with the sniffer ...
Rob Tillaart
BrainBooster
with 0x40 says:
end:2
req:0
is it dead?  :(
robtillaart
Quote
is it dead?
Don't know ...
DO you have 4K7 pull up resistors on the I2C lines?
Rob Tillaart
wayneft
I2C GPS Shield
Checkout my Open Source GPS Tracker on Kickstarter
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
