Topic: Troubles with Serial.print (Read 359 times) previous topic - next topic
nanar06
Hello,
         I want to Serial.print a string array and the print is stopping
         before the end of the printing sequence....
         There is also some strange caracters that appear like with the
         cde N°3 command line in the joint file....
         In general, with a great amount of print, I can see some
         strange behaviour with the print function...
         I have to precise that I'm working on an ARDUINO YUN and
         the Arduino EDI 1.8.6 Release....
              Thanks for your help !!! I'm Ok for other informations and tests....
                          Bests Regards....
ballscrewbob
You should supply the program or sketch you are using.
Please use CODE TAGS ( </> ) to post errors or code.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
