Topic: Arduino and TSOP1738 (Read 2193 times) previous topic - next topic
prashanthjbabu
  Im trying to interface the arduino with a TSOP1738 IR Receiver (38khz) .. I tried various libraries online to decode IR signals of any remote but none worked so far for me.. I initially connected the VCC and ground pins the other way round , could that have spoilt my TSOP1738?Is there any way i can check if it still works. Could anybody point me to a hello world code for receiving IR signals from a remote.
Thanks a lot..
RuggedCircuits
Quote
I'm afraid so. Reversing the supply voltage will destroy most electronic devices.
The first thing to check is to power it (properly!) with a power supply and measure the current. It should be very small, around 1mA according to the datasheet. If it's more than that the part is broken. If it's absolutely 0.0000 (measured with a DMM) the part is likely broken.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
prashanthjbabu
i guess it has broken.. i'll have to get another one..thanks for the reply..
