Loading...
Pages: [1] 2   Go Down
Author Topic: Arduino to control switches  (Read 896 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I want to use Arduino to control the production of hydrogen/oxygen via electrolysis, and the condensation of water from a peltier cooler.
Presumably I'd need 4 things:
1. A switch to initiate the electrolysis which I could control from Arduino
2. A switch to initiate the peltier which I could control from Arduino
3. The ability to measure how heavy the peltier gets (to know how much condensation has formed on it)
4. The ability to measure the water in collection vessel so I know when the electrolysis should stop (when the water gets to a certain level)
Now I have found this for 4, but other 3 I am stuck on, and would like some assistance as to what hardware I should get to accomplish this.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Well, all this kind of depends on whether you're doing this on an industrial scale (with industrial explosive atmosphere considerations), or at the kitchen sink with some old coffee jars.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
Quote
This depends upon the voltage and current of the electrolysis process. Or are you asking about how to do the actual electrolysis?
Quote
Same as above: what did you have in mind? My guess is that it's low-voltage high-current DC in which case a MOSFET would work, or a relay.
Quote
What kind of weight difference are you looking for? A change of a few grams, hundreds of grams? Most accurate, and most expensive, are going to be load cells. You will get by more cheaply with a force-sensitive resistor (FSR), like part SEN-09376 at Sparkfun. Those tend to be a bit wonky to work with as they "settle", age, have to be broken in, etc.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
Logged
Georgina Ontario
Offline Offline
Sr. Member
Arduino rocks
View Profile
Narwhal:
Your project is really not well defined. The title says it is about switches -- but you want to weigh something as well -- the weight of a vessel and the height of a liquid in a vessel. (You cannot measure quantity except gravimetrically -- and you are already doing that -- why the double check on the same data? Are you expect the water in your vessel to vary from the know standard?
Here is your switch though. You don't need an Arduino -- and it is consistent with the project definition that you have provided so far.
http://www.sparkfun.com/products/97
Now as for the weighing  -- I posted a simple application framework in this section that should get you started in programming.
This looks like a High School project and you want us to do your home work. That's fair enough -- some people love to help with those projects.
Maybe you should tell us what this is about and people are likely to be more sympathetic.
PS: Do you know how to be safe with hydrogen? Is this a supervised project? You do know about explosives -- right?
You do realize that you will supply more energy than you retrieve from the process -- right?
Logged
Just another Hacker
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
OK here is a clearer explanation of what I am trying to achieve.
Firstly I want to dehumidify the air into water (or ice in this case). To do this I am using a peltier element. I will need to be able to switch this element on and off via the Arduino (hence the need for a programmable switch). I will need to measure the weight to know when the peltier has collected enough ice to be turned to water (switching the peltier off will immediately cause the ice to heat up and fall into the water collection tank.
Secondly, I want to convert the water to oxygen and hydrogen via electrolysis, I will need to measure the water level to make sure their is enough water to submerge the electrolytes (hence the measuring of water levels), and I will need to be able to switch the electrolytic process on and off (hence the need for a programmable switch).
My reason for doing this is "just because".
Quote
I am not doing this on an industrial scale.
Quote
I am clearly not asking how to do the actual electrolysis, all I want to do is turn the process on and off via the Arduino. Voltage is 7.2 and current should be 500 mA (though I am open to the current varying to another up to 3A).
Quote
Peltier draws 3A from 10V of DC.
Quote
A few grams.
Quote
It is not a High School project.
Quote
I know how to be safe with hydrogen.
Quote
Yes.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
For switches you probably use logic level mosfets or solid state relays. There probably a lot of alternative methods for measuring humidity from a horse hair contraction/expansion to various electronics. As to the ice on the peltier you might look at an optical way to detrmine frost buildup. As to some of the other off the wall comments and concerns like "You do realize that you will supply more energy than you retrieve from the process -- right?", well, they mean well.  smiley-wink
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Red Sea, Saudi Arabia
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
Switching power from Arduino: some possibilities here:  (OK, that search didn't work!!!)
FET Switches: http://arduino-direct.com/sunshop/index.php?l=product_detail&p=60
Relay Boards:  =relay&s[title]=Y&s[short_desc]=Y&s[full_desc]=Y&s[sku]=Y&s[match]=all&s[cid]=0]http://arduino-direct.com/sunshop/index.php?l=search_list&s[search]=relay&s[title]=Y&s[short_desc]=Y&s[full_desc]=Y&s[sku]=Y&s[match]=all&s[cid]=0
Hope that works.. Sorry!
DISCLAIMER: I mentioned stuff from my own Shop...
« Last Edit: March 28, 2011, 08:22:56 am by Terry King » Logged
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Terry what search criteria did you use?
Logged
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
Sorry! I redid it differently.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Is there a manual for that FET switch? Or is it one of those things that are fairly standard to operate? If so is there a tutorial on this?
Quote
Can the Arduino perform such image analysis? I'm looking to make this totally Arduino based so a camera to a desktop is a bit of a no go. I am open to other ideas however.
Logged
Georgina Ontario
Offline Offline
Sr. Member
Arduino rocks
View Profile
Yes we do -- at least I do. Or I try.... not always successfully... smiley-roll-blue
There are an awful lot of ill defined projects that appear here. The process to help and provide references is baffling since people don't always make it clear what they are looking for.
If it is a student project we should be a lot more patient and understanding of the need to spell out the basics. ...but not willing to do a homework assignment..
Also -- there are often many solutions to the problems presented -- but not knowing the abilities of the person requesting the help makes it difficult to help sometimes.
People can give more information -- or less as they please -- but then people reading the request have to guess how to help. Then it's like pulling hen's teeth.
BTW: Here is a useful Refernce for people building add-on circuits.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Electronic+Circuits+Graf&x=0&y=0
Check out Volume Three for example...
http://www.amazon.com/Encyclopedia-Electronic-Circuits-Vol-3/dp/0830673482/ref=sr_1_2?ie=UTF8&qid=1301331468&sr=8-2
\Not sure if it is the best reference.
The books by Graf are excellent resources for explaining the questions of FET's and MOSfets etc...
In this case whether it is an NPN power transistor or a FET style Semiconductor is a non-issue in my mind -- the only question is -- can it pull the current to run the device you want operated, and can you supply a signal sufficiently strong to "saturate" the semiconductor device.
If you don't really understand the electronics side -- just buy commercial products which promise to do what you want. It's definitely faster and more certain -- even if a touch more expensive.
« Last Edit: March 28, 2011, 12:04:01 pm by WillR » Logged
Just another Hacker
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Optical and image are not really th same thing. There are little optical devices like below used in bots for distance and line detection that might be of use. If you have a dark place on your cooler (possibly colored by a black sharpie), then this gizmo might detect when the spot starts becomming lighter from frost buildup.
http://www.lynxmotion.com/p-58-single-line-detector.aspx
http://www.lynxmotion.com/p-260-sharp-gp2d12-ir-sensor.aspx
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
That's an interesting thought, I will try painting on of the peltier elements black and giving it a go with the single line detector, however a problem looms, the Peltier element's cold side will be facing the ground (so when it turns off the water will melt into the collection vessel), so to detect ice the single line detector would have to be below it, and would be subjected to a downpour of water. I'm not sure if I can waterproof this because I assume any lense I put around it will alter the IR signal.
Logged
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
http://arduino-info.wikispaces.com/Brick-4ChannelPowerFetSwitch
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Not sure what your overall objective is, but you may want to design with the intent that the water is removed from the surface as it condenses and not allow it to freeze on the surface.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
