Topic: Consulta (Read 416 times) previous topic - next topic
ingrid_rpm
Arduino: 1.8.6 (Windows Store 1.8.14.0) (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Sketch uses 247952 bytes (49%) of program storage space. Maximum is 499696 bytes.
Global variables use 28016 bytes (34%) of dynamic memory, leaving 53904 bytes for local variables. Maximum is 81920 bytes.
C:\Users\ingri\Documents\ArduinoData\packages\esp8266\tools\esptool\0.4.13/esptool.exe -vv -cd ck -cb 115200 -cp COM4 -ca 0x00000 -cf C:\Users\ingri\AppData\Local\Temp\arduino_build_340455/modulowifi.ino.bin
esptool v0.4.13 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
   setting board to ck
   setting baudrate from 115200 to 115200
   setting port from COM1 to COM4
   setting address from 0x00000000 to 0x00000000
   espcomm_upload_file
   espcomm_upload_mem
   setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
An error occurred while uploading the sketch
   flush start
   setting serial port timeouts to 1 ms
   flush complete
   espcomm_send_command: sending command header
   espcomm_send_command: sending command payload
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
resetting board
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
resetting board
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
trying to connect
   flush start
   flush complete
   read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
option enabled in File -> Preferences.
Robin2
@ingrid_rpm a description of what you are trying to do would help.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
larryd
Have you looked at the stickies which deal with posting questions?
https://forum.arduino.cc/index.php?topic=149014.0
No technical PMs.
The last thing you did is where you should start looking.
