Loading...
Pages: [1]   Go Down
Author Topic: Lilypad Temperature Sensor. Help  (Read 337 times)
Offline Offline
Newbie
View Profile
I am using the Lilypad Temperature sensor with the Lilypad Arduino w/ATmega328.
At this point I am having difficulties getting a consistent reading of the ambient temp.  It jumps from as low as 15 degrees Celsius to 25 degrees Celsius. The actual temp should be 24 degrees Celsius.
My code is below.  Any help would be really appreciated!
Code:
//analog input 0/digital 14
int tempSenPin = 0;
  pinMode(tempSenPin, INPUT);
  int reading = analogRead(tempSenPin);
  float voltage = reading * (3300 / 1024);
  float tempC = (voltage - 500)/10;
  Serial.print(tempC); Serial.println(" degrees C");
Logged
Threadtech: Fashion Meets Technology
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Analogpins don't need a pinMode to be set,
There is a math error in    voltage = reading * (3300 / 1024);    3300/1024 = allways 3
so this line just states   voltage = reading * 3;
to make it float voltage = reading * 3300.0 / 1024;   //  note the .0 to force float!
==> code below
Quote
So 25 degrees is an acceptable measurement, but 15 is not. As the math does not fluctuate It could be a loose contact; Or maybe you need to do an averaging of the temperature. I added a RAW reading print in the code below.
Can you post e.g. 20-50 readings?
Code:
int tempSenPin = 0;
  Serial.prinln("start");  // for debugging only to see it works.
  Serial.print("RAW: "); Serial.println(reading);
There is also some code on - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1262208606 - it uses different math.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
How is this wired up?  The conductive thread used for the lilypad is not electrically ideal BTW, it might be the problem.
Logged
Offline Offline
Newbie
View Profile
Thanks so much,
My temp sensor is returning much more consistent and accurate readings now using the code changes you suggested.
It may also be that I am now in an airconditioned office where the temperature is regulated.
Now to write some code to do something with my temp inputs : )
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
- red led is the temperature is hot, blue if too cold, green = perfect
- monitor max and min value during a day (optional with timestramp)
etc
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
