Topic: Lilypad Temperature Sensor. Help (Read 966 times) previous topic - next topic
colleenjmorgan
I am using the Lilypad Temperature sensor with the Lilypad Arduino w/ATmega328.
At this point I am having difficulties getting a consistent reading of the ambient temp.  It jumps from as low as 15 degrees Celsius to 25 degrees Celsius. The actual temp should be 24 degrees Celsius.
My code is below.  Any help would be really appreciated!
//analog input 0/digital 14
int tempSenPin = 0;
  pinMode(tempSenPin, INPUT);
  int reading = analogRead(tempSenPin);
  float voltage = reading * (3300 / 1024);
  float tempC = (voltage - 500)/10;
  Serial.print(tempC); Serial.println(" degrees C");
Threadtech: Fashion Meets Technology
robtillaart
Analogpins don't need a pinMode to be set,
There is a math error in    voltage = reading * (3300 / 1024);    3300/1024 = allways 3
so this line just states   voltage = reading * 3;
to make it float voltage = reading * 3300.0 / 1024;   //  note the .0 to force float!
==> code below
So 25 degrees is an acceptable measurement, but 15 is not. As the math does not fluctuate It could be a loose contact; Or maybe you need to do an averaging of the temperature. I added a RAW reading print in the code below.
Can you post e.g. 20-50 readings?
int tempSenPin = 0;
  Serial.prinln("start");  // for debugging only to see it works.
  Serial.print("RAW: "); Serial.println(reading);
There is also some code on - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1262208606 - it uses different math.
Rob Tillaart
MarkT
How is this wired up?  The conductive thread used for the lilypad is not electrically ideal BTW, it might be the problem.
colleenjmorgan
Thanks so much,
My temp sensor is returning much more consistent and accurate readings now using the code changes you suggested.
It may also be that I am now in an airconditioned office where the temperature is regulated.
Now to write some code to do something with my temp inputs : )
robtillaart
- red led is the temperature is hot, blue if too cold, green = perfect
- monitor max and min value during a day (optional with timestramp)
etc
Rob Tillaart
