Loading...
Pages: [1]   Go Down
Author Topic: How Can I Set Up an IP address for Ethernet Shield???  (Read 264 times)
Offline Offline
Sr. Member
Arduino rocks!
View Profile
every time i connect the ethernet shield to my laptop after it has been turned off/logged off i have to go into the arduino's code and change the ethernet's ip address...
this is because the ip address is "auto-assigned". see highlighted pic 1...
is there a way of assigning a pernament ip address by using the stuff in pic 2?
pic 1
pic 2
Logged
As always... Thanks for posting!!!
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Yes, just fill it in with the prefered numbers.
Be aware that you should use a number thatis not within the DHCP range.
assume DHCP manages 192.168.1.100 and up
e.g. IP Address 192.168.1.10
Gateway : 192.168.1.1            // your routers IP address
Netmask : 255.255.255.0
For DNS server you can use 192.168.1.1  // your router
hopes this helps.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Sr. Member
Arduino rocks!
View Profile
thanks i think that might work. will have to try it later when i am done tinkering with a robot...
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
If you have control over the wireless router you may be able to configure it to assign a fixed address to your laptop so it always gets the same IP address when it asks for an address to be assigned.
Logged
Offline Offline
Sr. Member
Arduino rocks!
View Profile
that's good to know... i just wish i knew what you were saying...
can u explain it so i, a simi-newbie to software, can understand it?
thanks
ps. i currently have more knowlage about circiutry, than i do software, or anything related to software for that mater.
(e.g. a few days ago I learned two new things in both of those fields: #1 what a digitalpotentiomiter is and how to use it #2 what the meaning of a "long" is)
Logged
Pages: [1]   Go Up
Print
Jump to:
