Loading...
Pages: [1]   Go Down
Author Topic: 1 servo OK 2 servo ça bug !  (Read 571 times)
Offline Offline
Newbie
View Profile
Bonjour,
j'ai branché deux servo sur deux sorties analogique différentes, et qu'ils sont piloté par deux potentiomètres différents.
Hors quand 1 seul est connecté ça marche, quand y'en a deux ça bug !
les servos font un aller retour à mis chemin du potentiomètre chose qu'ils ne font pas en temps normal...
voici le code !
merci d'avance
Code:
#include <Servo.h>
Servo myservo0;  // create servo object to control a servo
Servo myservo1;
int potpin0 = 0;  // analog pin used to connect the potentiometer
int potpin1 = 1;  // analog pin used to connect the potentiometer
int val1;    // variable to read the value from the analog pin
int val2;    // variable to read the value from the analog pin
  myservo1.attach(9);  // attaches the servo on pin 9 to the servo object
  myservo0.attach(11);  // attaches the servo on pin 9 to the servo object
  val1 = analogRead(potpin1);            // reads the value of the potentiometer (value between 0 and 1023)
  val1 = map(val1, 0, 179, 0, 1023);     // scale it to use it with the servo (value between 0 and 180)
  myservo1.write(val1);  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
  val2 = analogRead(potpin0);            // reads the value of the potentiometer (value between 0 and 1023)
  val2 = map(val2, 0, 179, 0, 1023);     // scale it to use it with the servo (value between 0 and 180)
  myservo0.write(val2);  // sets the servo position according to the scaled value
  delay(15);
Logged
Britanny
Offline Offline
Full Member
Mais vrai, j'ai trop pleuré, toute lune est atroce
View Profile
WWW
dans le référentiel Servo:
Quote
As of Arduino 0017, the Servo library supports up to 12 motors on most Arduino boards and 48 on the Arduino Mega. On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10, whether or not there is a Servo on those pins.
en Français: ça marche pas sur les pin 9 et 10!
Logged
Offline Offline
Newbie
View Profile
ok merci ^^
je m'étais basé sur l'exemple de arduino.cc qui utilise la pin9!
merci!
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
val1 = map(val1, 0, 179, 0, 1023);   >>   val1 = map(val1, 0, 1023, 0, 179);
 val2 = map(val2, 0, 179, 0, 1023);   >>  val2 = map(val2, 0, 1023, 0, 179);
    http://arduino.cc/en/Reference/Map
Lefty
Logged
Britanny
Offline Offline
Full Member
View Profile
WWW
map(value, fromLow, fromHigh, toLow, toHigh)
ouaip faut inverser les valeurs que tu as mises.
'l a fallu que je lise 2 fois le message de lefty pour voi ou ça allait pas...
je croyais qu'il s'était planté aussi..
Logged
Offline Offline
Newbie
View Profile
hey hey ça marche!
merci !
Logged
France
Offline Offline
Edison Member
There is an Arduino for that
View Profile
Quote
Pas exactement. Ca marche sur les broches 9 et 10 mais ça désactive analogWrite() et les fonctions PWM sur ces broches.
Logged
Pages: [1]   Go Up
Print
Jump to:
