Topic: Arduino MKR1000 - Couldn't find a Board on the selected port (Read 738 times) previous topic - next topic
Fillock
Hi.
I read many have a similar problem, but not the same: ArduinoMKR1ooo port is grayed out. Yes, double-click the reset button helps make the port visible again.
And when I start uploading/evaluating the code, It almost finishes and then fails with the words: "Couldn't find a Board on the selected port", and quite correct the port is not visible anymore. Interesting enough I can often see on "Freeboard.io" that the new values sometimes are updated on the board, even if it fails.
In periods of time things working stable, but suddenly it does not work anymore. I use a PC, the Arduino IDE and downloaded the latest libraries. I have tested on the 3 different MKR1000 boards, several USB ports, different USB cables, and 2 computers. There is no problem uploading to an Arduino Uno. I do not think there are any hardware issues.
My problem started when using "analogRead" and #include <dht11.h> , but removing it from the code doesn't fix the problem again, can it be a crash with libraries or something?
I don't know what to look for have to say. Thanks for any advice
ballscrewbob
On some of the very very early boards there were some issues with some of the basic sketches.
This was resolved with a newer firmware IIRC.
My BETA MKR1000 suffered some issues until the upgrade.
Could you check you have the latest firmware for your boards by using the check firmware version example sketch for the MKR.
See this post also
That was another side effect of early firmware but the instructions hold true.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Fillock
Thanks for answering.
I thought since my 3 MKR1000 behave the same way, the problem had to be on the PC software side. Running the test gave this result (under), so later today I will run the "Firmware and certificates Updater".
<WiFi101 firmware check.
WiFi101 shield: DETECTED
Firmware version installed: 19.4.4
Latest firmware version available : 19.5.4
Check result: NOT PASSED
 - The firmware version on the shield do not match the
   version required by the library, you may experience
   issues or failures.>
