Topic: hey guys some help? (Read 2835 times) previous topic - next topic
jaimehardtimes
Mar 28, 2011, 09:17 pm Last Edit: Mar 28, 2011, 09:41 pm by jaimehardtimes Reason: 1
hey guys im new to the forum and am having some issues..im trying to recreate user Furqan's project
it some remote controlled leds the problem is when i paste the code i  get the following error: :smiley-eek:
sketch_mar25a.cpp:12:10: error: #include expects "FILENAME" or <FILENAME>
sketch_mar25a:22: error: 'decode_results' does not name a type
sketch_mar25a.cpp: In function 'void setup()':
sketch_mar25a:27: error: 'irrecv' was not declared in this scope
sketch_mar25a.cpp: In function 'void loop()':
sketch_mar25a:37: error: 'irrecv' was not declared in this scope
sketch_mar25a:37: error: 'ampresults' was not declared in this scope
sketch_mar25a:38: error: 'results' was not declared in this scope
here is the code
Code: [Select]
/*   5 Channel ir remote control
   Created by Asghar Furqan
   A fully open-sourse program!
circuit:
ir module connected to pin 2(Digital)
led 1-2-3-4-5 connected to pin 3-4-5-6-7
#include <IRremote.h>
int RECV_PIN = 2;
int led1 =  7;
int led2 =  3;
int led3 =  4;
int led4 =  5;
int led5 =  6;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the ir receiver
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
if (irrecv.decode(&results)) {
  Serial.println(results.value, DEC);
  if(results.value == 16705559)  //if you want to configure with your remote controll change the results.value
    digitalWrite(led1, HIGH);   // set the LED on
 if(results.value == 16656599)
    digitalWrite(led1, LOW);   // set the LED off
  irrecv.resume(); // Receive the next value
  if(results.value == 16672919)
    digitalWrite(led2, HIGH);   // set the LED on
  if(results.value == 16697399)
    digitalWrite(led2, LOW);   // set the LED off
  if(results.value == 16689239)
    digitalWrite(led3, HIGH);   // set the LED on
  if(results.value == 16664759)
    digitalWrite(led3, LOW);   // set the LED off
  if(results.value == 16668839)
    digitalWrite(led4, HIGH);   // set the LED on
  if(results.value == 16676999)
    digitalWrite(led4, LOW);   // set the LED off
  if(results.value == 16674959)
    digitalWrite(led5, HIGH);   // set the LED on
  if(results.value == 16650479)
    digitalWrite(led5, LOW);   // set the LED off
also my ir reciever get really hot fast it seems to be pretty standard there are no product markings on it, its black and has 3 pins i pulled it off a dvd player
any help or guidance would be appreciated thanks!
robtillaart
Do you have copied the file - IRremote.h ?
It is porbably part of a library you need to use
Please modify your message, select the code and press the # button for proper layout, thanx
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Onions
At the top of the code, it says #include<IRremote.h>. This adds the functions of IR remote to your code. Check that you have th IR remote library in yout libraries file, then try again. (You will have to restart the IDE to get the new library to work).
Without having the library "IR remote" in your folder, the IDE will be looking for something that is not there, and it will not work.
Onions.
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) :D
bastukee
No trees were harmed by the transmission of this message. However a few million electrons were temporarily inconvenienced.
jaimehardtimes
thanks guys adding the library's solved the problem
it is receiving the remote signals now...just cant seem to get the leds to light up...i will plug away at it some more i guess
again thanks for the quick help!  :smiley-mr-green:
robtillaart
Quote
IR means infraRed - you can't see them - or are you a superhero ;)
Serious,
if(results.value == 16705559L)   ==>  needs an L for Long 16705559L
maybe that helps?
Rob Tillaart
