« on: March 28, 2011, 10:48:45 am » |
I have an Duemilanove and have followed the tutorial for the minimal circuit http://arduino.cc/en/Tutorial/ArduinoToBreadboard including downloading of the breadboard.zip I am in a Linux environment, using the Audrino IDE v22, blank 328p's after uploading the ArduinoISP sketch, I proceeded to select the "ATmega328 on a breadboard (8 MHz internal clock)" and the burned the bootloader using "Adruno as ISP". No errors were reported, so I burned the second one that I'd gotten. The problem arose when I went to upload my sketch. avrdude reported an invalid signature for the 328p sig = 0x1e9406, after googling for answers I found out this is the id for a 168. I've tried alternate suggestions including downloading a hex file for the 328 bootloader(from several years ago) and re-burning, to no avail, the Id is now 0x000000. and looks like I need to try an HV programmer to recover the chips. My question is how am I supposed to burn the bootloader for the 328p? In the bootloader folder all the hex file names start with 'atmega168'.
« Reply #1 on: March 28, 2011, 12:08:30 pm » |
Firstly the bootloader files are called 168 for both 168 and 328 as the bootloader is basically identical - only the flags and fuses and memory map differ. Sounds like it burnt the wrong bootloader somehow.
I have the 0021 software and "ATmega328 on a breadboard (8 MHz internal clock)" isn't on the list of boards - this sounds like a custom entry in boards.txt? It probably has the wrong bootloader file listed (you want ATmegaBOOT_168_atmega328.hex). The 328 at the end of the filename is crucial.
« Reply #2 on: March 28, 2011, 01:00:58 pm » |
The tutorial page http://arduino.cc/en/Tutorial/ArduinoToBreadboard has the download for the 8mhz internal clock on the 328. I altered none of the settings in the file, I assumed the tutorial any included files would be proper.
« Reply #3 on: March 28, 2011, 01:04:26 pm » |
If you have a 16MHz crystal you don't want to fuse the chip for internal clock.
« Reply #4 on: March 28, 2011, 01:41:43 pm » |
The project has no need for a clock greater than 8Mhz, which is why I chose to use the internal clock. I do not have a crystal, nor am interested in adding one, since it is a feature of the chip.
« Reply #5 on: March 28, 2011, 01:55:52 pm » |
I've found the boards.txt in the breadboard.zip - it specifies the bootloader
atmega328bb.bootloader.file=ATmegaBOOT_168_pro_8MHz.hex
I presume this is the only version for 8MHz internal clock - and its compiled for the 168...
Scotland
Have you had your Arduino fix today?
« Reply #6 on: March 28, 2011, 02:11:49 pm » |
This is what i've been using :
atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
atmega328bb.upload.protocol=stk500 atmega328bb.upload.maximum_size=30720 atmega328bb.upload.speed=57600
atmega328bb.bootloader.low_fuses=0xE2 atmega328bb.bootloader.high_fuses=0xD8 atmega328bb.bootloader.extended_fuses=0x07 atmega328bb.bootloader.path=atmega atmega328bb.bootloader.file=ATmegaBOOT_168_ATMEGA328_pro_8MHz.hex atmega328bb.bootloader.unlock_bits=0x3F atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.build.mcu=atmega328p atmega328bb.build.f_cpu=8000000L atmega328bb.build.core=arduino
Massachusetts, USA
« Reply #7 on: March 28, 2011, 03:00:15 pm » |
Were you using ArduinoISP to try to load the sketch? Does your Duemilanove have an ATmega168 in it? If so, you forgot to disable auto-reset and you're talking to the Arduino bootloader on the Duemilanove rather than the ArduinoISP sketch. They both speak variants of the STK500v1 protocol. Disable auto-reset by connecting a small capacitor (1-10 microfarad) from the Reset pin of the Duemilanove to the Ground pin. (The + side of the capacitor goes to Reset and the - side to Ground.)
« Reply #8 on: March 28, 2011, 03:14:57 pm » |
Were you using ArduinoISP to try to load the sketch? Does your Duemilanove have an ATmega168 in it? If so, you forgot to disable auto-reset and you're talking to the Arduino bootloader on the Duemilanove rather than the ArduinoISP sketch. They both speak variants of the STK500v1 protocol. No, not uploading with AudrinoISP. No, my Duemilanove has a 328p. I had disabled the auto reset. Also pulled the chip from the Duemilanove as the tutorial stated.
Massachusetts, USA
« Reply #9 on: March 28, 2011, 05:29:35 pm » |
For some reason the bootloader thinks it was compiled for an ATmega168 and not an ATmega328P.
Ick.
« Reply #10 on: April 09, 2011, 10:27:19 pm » |
Thanks spycatcher2k. Worked perfectly. I did notice this has to be added to the boards.txt in the hardware/arduino directory. If added according to the tutorial, there will be compiling issues. This is what i've been using :
« Reply #11 on: April 09, 2011, 10:48:52 pm » |
There is no way the 168 bootloader hex file would work for 328P, that's simply impossible, since the bootloader section starting address are completely different. Make sure you are burning a bootloader hex file that is compiled for 328P with the starting address set correctly
I'm an electrical engineering student. I designed the USnooBie (V-USB dev kit) which is sold at Seeed Studio
Portugal
« Reply #12 on: April 11, 2011, 09:46:31 am » |
Hi, I'm a newbie on electronics in general, and I've been trying for several days to use an ATMega328p on a breadboard with the minimal configuration as stated in the above referred tutorial. I have a question related to this topic.
My 328s are all preloaded with the regular Arduino bootloader and I can upload sketches on all of them using the Arduino board. I'm trying to burn the 'ATmegaBOOT_168_ATMEGA328_pro_8MHz.hex' using Arduino as ISP (with another 328p on Duemilanove), but AVRDude reports an Invalid Device Signature (even when disabling the auto-reset).
Is it possible that because the 328p are already loaded with the 16MHz bootloader, I will need to add a 16MHz crystal just to be able to burn the new bootloader? I find it strange that, when using avrdude by command line, it reads all the fuses as 0x00 and the signature as 0x00 0x00 0x00 (hence Invalid Device Signature). That's what made me think that maybe I need the crystal for burning the bootloader...
If it helps, I've tried it with 0022 on Win7 32bit and 0021 on WinXP, and already tried several configurations that I read on this forum and several other sites.
« Reply #13 on: April 11, 2011, 10:04:00 am » |
You will need the 16 MHz crystal, but it is because of the fuse bits are set for external crystal, not because of the hex file.
Portugal
« Reply #14 on: April 16, 2011, 06:25:55 pm » |
Thanks! Bought the crystal today and burned the bootloader successfully. I could also upload a blink sketch and it is all working well...
