Topic: Basic suggestions for IDE usability improvements (Read 5577 times) previous topic - next topic
keystoneclimber
1.  The IDE should have the ability to both remember and restore its previous window state (i.e. size, maximized, screen #, etc.) and terminal height on next start up.
2.  A "tabbed" IDE should allow the user to open an existing file in a new tab.  Otherwise, you should have the ability to hide the tab. (What is the point of one tab?)  Currently, "Close" (Ctrl+W) has the exact same functionality as "Quit" (Ctrl+Q).  The proper functionality of close would be to close the current tab and leave the IDE open.
3.  More (most?) of the IDE preferences should be modifiable from within IDE. (worries about making things "too complicated" are easily solved with a simple check box that either enables or hides the advanced options)  All options in the preferences file that aren't modifiable from within IDE should be thoroughly explained preferably both in the manual and via comments in the actual preferences file.
4.  IDE should have the option to auto save the current sketch upon successful compilation (verify).
GaryP
And it would be nice to see two things without need to surf the menu:
1. Active COM-port
2. Active Board type.
Cheers,
Kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
dwhitcombe
I heartily second the "active serial port" and "active board type" notifiers.
There's lots of real estate in the ide -- That big blue bar on the bottom that houses the incredibly tiny line number, for instance (it's capable of being updated dynamically as the cursor moves around, stick "Serial: /dev/ttyACM0" on the right side of the bar. That'd be sweet when you've got two instances of the IDE open, and you're wondering... "Is board one on /dev/ttyUSB0 or /dev/ttyUSB1?"
I usually unplug a USB then do a quick "ls /dev/ttyU*" to see which one I unplugged...
Boffin1
The active port would be very handy,  I have been developing a telemetry system with 2 arduinos plugged in to the one PC, and I keep ending up with 2 receivers or 2 transmitters when I forget to swap the port.
45 years of editing projects with a knife and soldering iron, then I found Arduino !
liuzengqiang
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
siklosi
Im using a lot autoit and I like help in scite... when cursor is on some command and i press F1 i get language reference for that command. In case of arduino I have to go to browser arduino.cc reference... language... find command... So some F1 functionality would be appreciated
Aubrey
I'd love to see the IDE conform with Linux standards wrt use of the middle mouse button (cut and paste).  Drives me crazy.
liuzengqiang
Count me out on that. I use a PC. I don't think Mac users would benefit from this either. Maybe an option but not enforced.
bombasticbob
Don't want to complain since it's pretty usable as-is.
biggest improvement I can think of would be to fully integrate the IDE with Eclipse, or at least have better integration between the output window (for compiles) and the source viewer.
But what I _really_ want (and hardly anyone supports it) is what MS calls "virtual space".  If I go to the end of a long line and use cursor up/down I don't want my horizontal cursor going to the end of each line, bouncing around.  I want it to stay in the SAME COLUMN regardless of how long the lines are.  And I want all of the excess white space automatically trimmed on EVERY LINE OF CODE.  The auto-indent often inserts a lot of excess white space.  But I have utilities that can trim it already.
Also I would like to see the actual command lines being sent to avrdude so that I can troubleshoot problems more easily.  Yeah, I can always do that with a shell script, but I don't want to have to go there.
smeezekitty
And add upload without compiling to the list.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
Yot
Quote
...see the actual command lines being sent to avrdude...
Press shift when hitting upload.
Jeroen
smeezekitty
I actually use both Linux and Windows on different computers and cannot stand the middle click paste.
Resistors for LEDS!
CanyonCasa
And the opposite, an icon to compile without upload.
smeezekitty
Resistors for LEDS!
frank26080115
A "upload without compile" button would solve a lot of issues regarding "out of sync"
