Topic: Basic suggestions for IDE usability improvements (Read 5218 times) previous topic - next topic
CrossRoads
My laptop doesn't have a middle button.
I just use CTRL-C & CTRL-V to copy  & paste. Haven't gotten used to right-click this & right-click that.
CrossRoads
Oh - and my calendar doesn't 7s, and my phone doesn't have a 5 ...
(Thanks Steven Wright!)
Beardy241
I'd like the "Done Uploading" notice to disappear once I start editing again because I often lose track of whether the code changes I've just made are uploaded or not.
Could we have an option (maybe a tick box on the tool bar) that would automatically open the Serial Monitor after an upload.  Many projects deliver serial feedback so this would be a 'upload and get on with it option' rather than upload, wait, then open Serial Monitor.
When 'Auto Format'  scrolls the current cursor position to the top of the screen I often lose my place.  Could it stay still please?
I hope these are acceptable
Many thanks for all you've done, are doing and will do!
Clark_Jones
I'd like to see the Serial Monitor send "traffic" directly to a file on the host computer.
When you have large amounts of data coming from the Arduino, cut & paste can be a real PAIN when you're trying to find the one character clues in the datastream.
The option to "prefix" data going to the Arduino with, say, "<", and that coming from Arduino with, say, ">" would also be nice, but this is much less important than saving all the data to a file.
Clark_Jones
Another, separate comment on the IDE:  Using it is certainly a "retro" experience.  I've been using various debugging tools for well over 40 years, and this one is certainly a thowback to the capabilities we saw in the 1970s:  wanna find out what's happening in your program?  Just throw in a few more "printf()" calls (or whatever the syntax for the language you're using).
More modern IDEs include the capability to set breakpoints, run from start to the first breakpoint encountered, run from the current breakpoint to the next breakpoint, "single step" through a program (or, if you prefer, "sketch"), examine the contents of variables (and let the user specify variables to display at every breakpoint), and even modify those contents.
Although "debugging by printf()" is still a viable method in some instances, using breakpoints can be much quicker, and, in my not-so-humble opinion (based on more than 40 years of programming experience), it can be a good learning tool for the beginner to be able to "watch" his/her code execute.
PaulS
Quote
Well, that all works great for debugging a program running on the same machine as the debugger. In the case of the Arduino, the code is NOT running on the PC, and there is no debugger for the Arduino. No keyboard (or output device), either.
westfw
Quote
The AVR lacks some of the "standard" debugging capabilities of many CPUs (ie "single step mode"), and Atmel doesn't document the debugging protocols that the chip does support.  :-(
robtillaart
Quote
just found this doc - http://winavr.sourceforge.net/AVR-GDB_and_AVaRICE_Guide.pdf -
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
westfw
Yes, and it requires the Atmel JTAGICE to talk to AVR chip. :-(
(but it's better than nothing.)
Simpson_Jr
Possibility to copy&paste data in the terminal window.
Using hyperterminal or putty instead of the arduino one it's possible to copy/past data. Their connections need to be opened/closed manually every time a small piece of code has changed/needs to be uploaded though.
Arduinos terminal has a great advantage since it automatically closes when uploading. One click also opens it again, it takes good care of the double function of the serial port. But unfortunately it has no copy&paste. :-(
Yot
Often it's possible to use those when the right-click menu doesn't come up. It is possible in the serial monitor and in the black part of the ide.
regards,
Jeroen
Milor
al1fch
Quote
Some successfull retro engennering is on the way for  undocumented debugWire protocol  :
http://ruemohr.org/docs/debugwire.html
liudr
Say arduino has a keyboard and a monitor, how would you be able to debug on it at a level higher than assembly? I don't know how arduino can maintain a variable list since its code is compiled and it knows no source code. Just my thinking. I don't know enough about a debugger though.
I used turbo C and TASM in DOS. You get decent debug tools. You can display variable values (don't remember if it tracks changes or not).
Just curious, if you get a hardware debugger like dragon, what do you get to do? Pause execution and peek at every memory and register? I'm thinking about getting one but then my programming skill improved a bit, just enough to not freeze arduino.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
