Topic: I am trying to access the console of the yun. (Read 533 times) previous topic - next topic
hz348m
however, I got the message showed in the figure attached.
I got one time typing " lin and <enter>."
the message does not stop.
U.Boot 1.1.5-linino-g1759316-dirty (Oct 4 2015 - 02:12:32)
Linux Board (ar9331) U-boot
DRAM:
I have just bought the yun.
ballscrewbob
For first time use and configuration it is often best to use an Ethernet cable.
Then find the IP if the YUN via DHCP in your router and talk to it via the IP shown in there via a web page.
Yours does look to be stuck in a loop but I would try Ethernet first.
Errors / logs and such should really be posted using CODE TAGS ( </> ) btw.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
