Topic: EMG Sensor to control servo not working (Read 297 times) previous topic - next topic
Alexandermn19
Hey guys, i got a Grove EMG Sensor attached to the Grove shield on pin A0, however the value in the serial plotter is not changing when I flex my muscles and therefor can't move the servo motor...
Anyone knows why? Here is my code:
Code: [Select]
#include <Servo.h>
//Threshold for servo motor control with muscle sensor.
//You can set a threshold according to the maximum and minimum values of the muscle sensor.
#define THRESHOLD 250
//Pin number where the sensor is connected. (Analog 0)
#define EMG_PIN 0
//Pin number where the servo motor is connected. (Digital PWM 3)
#define SERVO_PIN 3
//Define Servo motor
Servo SERVO_1;
/*-------------------------------- void setup ------------------------------------------------*/
void setup(){
  //BAUDRATE set to 115200, remember it to set monitor serial properly.
  //Used this Baud Rate and "NL&CR" option to visualize the values correctly.
  //Set servo motor to digital pin 3
  SERVO_1.attach(SERVO_PIN);
/*--------------------------------  void loop  ------------------------------------------------*/
void loop(){
  //The "Value" variable reads the value from the analog pin to which the sensor is connected.
  int value = analogRead(EMG_PIN);
  //If the sensor value is GREATER than the THRESHOLD, the servo motor will turn to 170 degrees.
  if(value > THRESHOLD){
    SERVO_1.write(170);
  //If the sensor is LESS than the THRESHOLD, the servo motor will turn to 10 degrees.
  else{
    SERVO_1.write(10);
  //You can use serial monitor to set THRESHOLD properly, comparing the values shown when you open and close your hand.
  Serial.println(value);
Thanks in advance
nielyay
Is the wiring correct?
Sorry, i never used EMG sensor before, but i found this page.
Code: [Select]
    SERVO_1.write(170);
    SERVO_1.write(10);
Code: [Select]
*Remake this TRESHOLD into new value setup.
