Topic: SD error (hijack) (Read 899 times) previous topic - next topic
SixtoD
when i used
Code: [Select]
#include <SPI.h>
//#include <SD.h>
#include <SdFat.h>
extern SdFat SD;
i get error msg
Error compiling for board Arduino/Genuino Uno.
AWOL
when i used
Code: [Select]
#include <SPI.h>
//#include <SD.h>
#include <SdFat.h>
extern SdFat SD;
i get error msg
But you couldn't be bothered to post the code or the error message?
Is that approach working for you?
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
SixtoD
Code: [Select]
#include <SPI.h>
//#include <SD.h>
#include <SdFat.h>
extern SdFat SD;
File myFile;
File tempFile;
char cr;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  tempFile = SD.open("temp.txt", O_WRITE | O_CREAT | O_TRUNC);
// skipped/blocked the first Line OPEN
      bool firstLine = true;
while (myFile.available()) {
  int c = myFile.read();
  if (firstLine) {
    if (c == '\n') {
      firstLine = false;
  Serial.write(c);
  tempFile.write(c);
myFile.close();
tempFile.close();
// skipped/blocked the first Line CLOSED
loop();
  } //if(myFile) closing
  else {
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
// nothing happens after setup
just wanted to save all output to temp.txt, then i will delete the test.txt and rename the temp.txt to test..txt
Lucario448
I don't see like you were doing such thing.
SixtoD
just want to know how to use hehe
Code: [Select]
#include <SdFat.h>
extern SdFat SD;
I want to rename the temp.txt,
Ive search in this forum, they all say that the SdFat is the only solution to rename a file
but im getting an error msg "Error compiling for board Arduino/Genuino Uno."
PaulS
Quote
That message is the LAST message. We need to see your complete code AND ALL of the error messages.
You also need to explain why you have added the extern statement to the code.
SixtoD
Code: [Select]
#include <SPI.h>
//#include <SD.h>
#include <SdFat.h>
extern SdFat SD;
File myFile;
File tempFile;
char cr;
  while (!Serial) {
  if (!SD.begin(4)) {
    while (1);
  if (firstLine) {
    if (c == '\n') {
      firstLine = false;
  Serial.write(c);
  tempFile.write(c);
myFile.close();
tempFile.close();
loop();
  else {
this is my whole code
and im getting this error msg when I used the extern SdFat
Code: [Select]
PaulS
Quote
That is not the only message, though.
SixtoD
#8
Sep 17, 2018, 06:31 pm Last Edit: Sep 17, 2018, 07:13 pm by SixtoD
sorry, i thought thats the only error message.
Code: [Select]
Desktop\blahblah\skip_first_line_and_write_to_temp_file__experiment\skip_first_line_and_write_to_temp_file__experiment.ino:3:19: fatal error: SdFat.h: No such file or directory
 #include <SdFat.h>
compilation terminated.
exit status 1
Lucario448
The library's folder isn't placed in the correct location. This locaton is: "Documents" folder>Arduino>libraries
