Topic: 4D Systems uOLED 96 SGC (Read 3292 times) previous topic - next topic
StaticDet5
First, I need to throw out some massive compliments:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1291304406
Kevin Kibbe and Prawnhead put this together, even though every other resource points to this library, which I can't seem to make work:
http://jennylc.com/4d/
I changed some of Kevin and Prawn's code to work with the uOLED-96-SGC (or uOLED-96-G1-SGC or uOLED-96-G1(SGC)).
PDE Code
Code: [Select]
#include "Oled.h"
#include <string.h>
#define DIGI_A        2    // Values changed in line with
#define DIGI_B        3    // data from shieldlist.org
#define DIGI_C        4    //
#define OLED_WIDTH    96
#define OLED_HEIGHT   64
OLED myOLED(7,8,2500,57600);
int color= 0;
int tick = 0;
int ax = random(1,50);
int ay = random(1,10);
int ag = 1;
int af = 3;
int bx = random(50,160);
int by = random(30,128);
int bg = 3;
int bf = 2;
int latch=0;
int colour = 0;
int delta = 5;
int change = delta;
 Serial.begin(57600);
 pinMode(10, OUTPUT);
 digitalWrite(10,HIGH);
 myOLED.Init();
 myOLED.Clear();
 int color1 = myOLED.get16bitRGB(255,0,0);
 int color2 = myOLED.get16bitRGB(0,0,255);
 int ax = random(92)+2;
 int ay = random(60)+2;
 int bwidth = random(92-ax);
 int bheight = random(60-ay);
 myOLED.PenSize(1);
 myOLED.DrawRectangle(0, 0, OLED_WIDTH - 1, OLED_HEIGHT - 1, myOLED.get16bitRGB(255,0,0));
 colour += change;
 if (colour > (255-delta)) change = -delta;
 if (colour < delta) change = delta;
 myOLED.DrawString(20, 45, 2, myOLED.get16bitRGB(0,0,colour), 1, 1, "12:58");
 myOLED.DrawString(45, 10, 0, myOLED.get16bitRGB(255-colour,0,0), 1, 1, "Test");
OLED.h Code:
Code: [Select]
Oled.h - Oled Display library for Arduino & 4d Systems Serial OLEDs
Copyright(c) 2010 Paul Karlik
Original Source Copyright(c)2007 Oscar Gonzalez
Licensed under the MIT license:
http://www.opensource.org/licenses/mit-license.php
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
16bitColor from RGB by YAPAN.org's small utilities for Arduino
http://www.opensource.org/licenses/bsd-license.php
#ifndef Oled_h
#define Oled_h
#include <inttypes.h>
#define OLED_BAUDRATE 57600
#define OLED_RESETPIN 8
#define OLED_INITDELAYMS 1000
#define OLED_DETECT_BAUDRATE        0x55
#define OLED_CLEAR 0x45
#define OLED_BKGCOLOR 0x42
#define OLED_COPYPASTE 0x63
#define OLED_SAVE_CHAR 0x41
#define OLED_DISPLAY_CHAR 0x44
#define OLED_LINE 0x4C
#define OLED_CIRCLE 0x43
#define OLED_CIRCLEFILL 0x69
#define OLED_PUTPIXEL 0x50
#define OLED_READPIXEL 0x52
#define OLED_RECTANGLE 0x72
#define OLED_SETPEN 0x70
#define OLED_SETFONTSIZE 0x46
#define OLED_FONT5X7 0x01
#define OLED_FONT8X8 0x02
#define OLED_FONT8X12 0x03
#define OLED_TEXT                       0x53
#define OLED_TEXTFORMATED 0x54
#define OLED_COMMAND_CONTROL        0x59
#define OLED_COMMAND_DISPLAY        0x01
#define OLED_COMMAND_CONTRAST        0x02
#define OLED_COMMAND_POWER 0x03
#define OLED_ACK 0x06
#define OLED_NAK 0x15
class OLED
 public:
   OLED(uint8_t pinPower, uint8_t pinReset, uint8_t baudRate, uint8_t startUpTimer);
   uint8_t Init();
   unsigned int get16bitRGB(uint8_t red, uint8_t green, uint8_t blue);
   uint8_t ResetDisplay();
uint8_t Clear();
uint8_t PutPixel(uint8_t x, uint8_t y, unsigned int color);
uint8_t PenSize(uint8_t size);
uint8_t DrawLine(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, unsigned int color);
uint8_t DrawRectangle(uint8_t x, uint8_t y, uint8_t width, uint8_t height, unsigned int color);
uint8_t DrawCircle(uint8_t x, uint8_t y, uint8_t radius, unsigned int color);
uint8_t SetFontSize(uint8_t FontType);
uint8_t DrawText(uint8_t column, uint8_t row, uint8_t font_size, char *mytext, unsigned int color);
       uint8_t DrawString(uint8_t column, uint8_t row, uint8_t font_size, unsigned int color, uint8_t width, uint8_t height, char* text);
uint8_t DrawSingleChar(uint8_t column, uint8_t row, uint8_t font_size, uint8_t MyChar, unsigned int color);
uint8_t CopyPast(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, uint8_t width, uint8_t height);
uint8_t SaveBitChar(uint8_t slot, uint8_t data1, uint8_t data2, uint8_t data3, uint8_t data4, uint8_t data5, uint8_t data6, uint8_t data7, uint8_t data8);
uint8_t DisplayBitChar(uint8_t slot, uint8_t x, uint8_t y, unsigned int color);
 private:
uint8_t _pinReset;
uint8_t _pinPower;
uint8_t _baudRate;
uint8_t _startUpTimer;
   void write(uint8_t value);
#endif
I changed the code in the PDE and the .h file so that all the baud rates are at 57600.
I also changed the PDE code to the correct width and height for the 96.
Then I changed the text size in the DrawString commands at the bottom of the loop.
The CPP code is unchanged.
I'm using pin 8 as the reset, I have a micro-SD card in the display, and the two pins un-jumpered.
StaticDet5
Here is the CPP code for completeness's sake:
Code: [Select]
#include "Oled.h"
#include <stdio.h>
#include <string.h>
#include "WProgram.h"
OLED::OLED(uint8_t pinPower, uint8_t pinReset, uint8_t baudRate, uint8_t startUpTimer){
  _pinReset = pinReset;
  _pinPower = pinPower;
  _baudRate = baudRate;
  _startUpTimer = startUpTimer;
  pinMode(_pinPower, OUTPUT);
  pinMode(_pinReset, OUTPUT);
  digitalWrite(_pinPower, HIGH);
  //pinMode(_pinReset, OUTPUT);
void OLED::write(uint8_t value) {
  Serial.print(value, BYTE);
char GetResponse()
byte incomingByte = OLED_ACK;
while (!Serial.available()) { delayMicroseconds(150); }
incomingByte = Serial.read();
return incomingByte;
uint8_t OLED::Init()
ResetDisplay();
delay(OLED_INITDELAYMS);
Serial.write(OLED_DETECT_BAUDRATE);
GetResponse();
// YAPAN.org's small utilities for Arduino //
unsigned int OLED::get16bitRGB(uint8_t red, uint8_t green, uint8_t blue)
  uint8_t r = red >> 3;  // red: 0-31
  uint8_t g = green >> 2;  // green: 0-63
  uint8_t b = blue >> 3; // blue: 0-31
  unsigned int bitRGB = (r << 11) + (g << 5) + b;
  return bitRGB;
uint8_t OLED::Clear()
Serial.write(OLED_CLEAR);
    GetResponse();
uint8_t OLED::ResetDisplay()
digitalWrite(OLED_RESETPIN, LOW);
delay(10);
digitalWrite(OLED_RESETPIN, HIGH);
delay(10);
uint8_t OLED::PutPixel(uint8_t x, uint8_t y, unsigned int color)
Serial.write(OLED_PUTPIXEL);
Serial.write(x); // X
Serial.write(y); // Y
// Color
Serial.write(color >> 8); // MSB
Serial.write(color & 0xFF); // LSB
    GetResponse();
uint8_t OLED::PenSize(uint8_t size) {
  Serial.write(OLED_SETPEN);
  Serial.write(size);
  GetResponse();
uint8_t OLED::DrawLine(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, unsigned int color)
Serial.write(OLED_LINE);
Serial.write(x1); // X1
Serial.write(y1); // Y1
Serial.write(x2); // X2
Serial.write(y2); // Y2
// Color
    GetResponse();
uint8_t OLED::DrawRectangle(uint8_t x, uint8_t y, uint8_t width, uint8_t height, unsigned int color)
Serial.write(OLED_RECTANGLE);
Serial.write(x); // X1
Serial.write(y); // Y1
Serial.write(x+width); // X2
Serial.write(y+height); // Y1
// Color
GetResponse();
uint8_t OLED::DrawCircle(uint8_t x, uint8_t y, uint8_t radius, unsigned int color)
    Serial.write(OLED_CIRCLE);
Serial.write(radius); // Radius
// Color
    GetResponse();
uint8_t OLED::SetFontSize(uint8_t FontType)
    Serial.write(OLED_SETFONTSIZE);
    Serial.write(FontType);
    GetResponse();
uint8_t OLED::DrawText(uint8_t column, uint8_t row, uint8_t font_size, char *mytext, unsigned int color)
Serial.write(0x73); // Formated Text
    // Adjust to center of the screen (26 Columns at font size 0)
        int newCol = 13 - (strlen(mytext)/2);
        Serial.write(column); // Column
Serial.write(row); // Row
Serial.write(font_size); // Font Size
// Color
for (int i=0 ; i<strlen(mytext) ; i++)
Serial.print(mytext[i]); // character to write
Serial.print(0x00, BYTE); // string terminator (always 0x00)
    GetResponse();
// Added CMurphy 2010-12-12
uint8_t OLED::DrawString(uint8_t column, uint8_t row, uint8_t font_size,
  Serial.write(OLED_TEXT);
  Serial.write(row);
  // Color
  Serial.write(width);
  Serial.write(height);
  while(*text != '\0') Serial.write((char) *text++);
  Serial.write((uint8_t) 0);
  GetResponse();
uint8_t OLED::DrawSingleChar(uint8_t column, uint8_t row, uint8_t font_size, uint8_t MyChar, unsigned int color)
Serial.write(OLED_TEXTFORMATED);
    Serial.write(MyChar);
    Serial.write(row);
// Color
    GetResponse();
uint8_t OLED::CopyPast(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, uint8_t width, uint8_t height)
Serial.write(OLED_COPYPASTE);
Serial.write(width); // Box Width
Serial.write(height); // Box Height
    GetResponse();
uint8_t OLED::SaveBitChar(uint8_t slot, uint8_t data1, uint8_t data2, uint8_t data3, uint8_t data4, uint8_t data5, uint8_t data6, uint8_t data7, uint8_t data8  )
Serial.write(OLED_SAVE_CHAR);
Serial.write(slot); // Char Slot
Serial.write(data1); // Data 1
Serial.write(data2); // Data 2
Serial.write(data3); // Data 3
Serial.write(data4); // Data 4
Serial.write(data5); // Data 5
Serial.write(data6); // Data 6
Serial.write(data7); // Data 7
Serial.write(data8); // Data 8
    GetResponse();
uint8_t OLED::DisplayBitChar(uint8_t slot, uint8_t x, uint8_t y, unsigned int color)
Serial.print(OLED_DISPLAY_CHAR, BYTE);
// Color
    GetResponse();
StaticDet5
#2
Mar 29, 2011, 03:30 am Last Edit: Mar 29, 2011, 03:36 am by Static Reason: 1
And I'm a bit of a moron, because I forgot the whole reason that I started this thread.
I need to mirror this display (I'm going to be looking at it after I reflect it in a mirror).
I need to implement this:
[http://4d.websitetoolbox.com/post?id=2392828&pid=1267872258#post12678722585]http://4d.websitetoolbox.com/post?id=2392828&pid=1267872258#post1267872258[/url]
I can't seem to figure out how to send multiple commands to the system.  I've tried a couple of different ideas, but either they don't work, or I hang the display.
If I get any information from them, I'll post up here, and vice versa.
Yot
Hi Static,
For example the CopyPast(..) method sends multiple commands. You would need to structure you method about the same as that for writing to one of the registers. (the display_SetReg thing). The exact command to do that is in the commands pdf.
The actual registers in the controller inside the oled screen (Not the goldelox controller) are in a pdf for your oled screen (again, not the goldelox). I looked for a short time but i couldn't find the datasheet for the .96" screen. For the 1.7" i have it's the SEPS525 Datasheet. (from http://www.4dsystems.com.au/prod.php?id=20 )
Hope this gives some leads.
Jeroen.
ps. There are pre-invented wheels (library). search for uoled library or displayshield4d . I made one myself as well with the switch inputs, sd-card access, sound output and the possibility to use different hardware serial ports in case of an arduino mega. Drop me a message if you want a copy.
StaticDet5
Wow!
I was reading your stuff yesterday.  I love the internet, you run into the neatest people.  It's always thrilling to me when I meet folks who have already "blazed a trail".
I tried your work yesterday, and couldn't get it to work with the 96.  I got a reply on the 4D forums, and it seems that the 96 isn't capable of doing this without pre-programming it.  I'm surprised by this, as the display just screams to be embedded in something, and used indirectly (Across a mirror).
When I find a solution, I'll post it.
Thanks again.
Yot
Not sure which lib. you are using atm but i haven't posted it somewhere yet. I was asked for a copy a few times so that may be one of the libs you saw.
Maybe the disp config file gives some clues as to what registers there are in the screen controller (not the goldelox controller on the board).
Jeroen.
ps. I was a noob only a year ago. Probably still am. :)
StaticDet5
I've been a noob all my life.  Just when you think you've seen it all, something new and different comes along.
That's the problem with not keeping notes.  I thought you posted your successful code, and I tried it, and it didn't work.  I was literally trying everything that I could find, for awhile.  As it stands, the code I'm using is going to need to be expanded, so that more functions can be implemented.  I think I'm going to have to learn C, or whatever the libraries are programmed with.
Post your code up!  Share the discoveries.
Yot
I won't post it yet. Needs some thing before i do that. If you really want you can have a copy. A work in progress version that is.
Jeroen.
StaticDet5
I'd love to look at it, if for no other reason that it will help me learn more (and faster).
