Topic: PWM coding for BLDC motor (Read 2108 times) previous topic - next topic
adityasreekumar
I wanted to generate a 0.92 ms to 1.92 ms, varying ON TIME PWM signal. Total signal duration is 20ms. For testing the code, i tried generating the maximum and minimum signals.
CODE:
int inmain;
int in1;
int ipmain = 22;  //input control pin
int ip1 = 24;
int op1 = 53;    //PWM output pin
pinMode(op1,OUTPUT);
pinMode(ipmain,INPUT);
pinMode(ip1,INPUT);
inmain=digitalRead(ipmain);
in1=digitalRead(ip1);
if(inmain==LOW)
  digitalWrite(op1,HIGH);
  delayMicroseconds(900);
  digitalWrite(op1,LOW);
  delay(19.1);
  delayMicroseconds(2000);
  digitalWrite(op2,LOW);
  delay(18);
I want to give this signal to an ESC to power the BLDC motor. The code however doesnt seem to be working. Pls Help
Aditya
PaulS
Code: [Select]
delay(19.1);
Apparently, you haven't bothered to look at the documentation for the delay function.
Quote
Maybe it's just taking a short vacation.
On the other hand, you could try explaining what it does do, what it does not do, and how what it does differs from what you want it to do.
There are too many things you haven't said for us to be able to help you. For instance, what is connected to pins 22 and 24? Do you KNOW that you can read consistent data from those pins? That is, are you certain that the results of digitalRead on those pins is consistent with the input you are providing?
AWOL
#2
Mar 29, 2011, 10:46 am Last Edit: Mar 29, 2011, 12:49 pm by AWOL Reason: 1
Quote
Have you thought about using the servo library?
It makes PPM, but 9/10 of people (when questioned) couldn't tell the difference.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
GrooveFlotilla
Your thread title is misleading; the code is for an ESC, so the motor type is irrelevant.
AWOL nailed it.
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
