Topic: Use DC PWM Speed Controller as Potentiometer? (Read 633 times) previous topic - next topic
ardustar
Hi There,
I have this speed controller here: Speed Controller
It only has power + - and motor + -
Normally a potentiometer has 3 pins? So, can I use it as a simple pot and if yes how to wire it to the arduino?
Thanks
Robin2
I would not think that is possible.
You need to provide more information. Are you trying to replace a potentiometer in something? If so, what?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
ardustar
I just want to control the speed of a stepper motor and thought this speed controller could do this. But it seems it is not the right tool for the job....
Robin2
That is not enough information.
What is controlling the stepper motor?
Why not just use a potentiometer?
And those two questions barely scratch the surface of what you are not telling us. Please describe the complete project and all its components and how they connect together.
...R
Wawa
I just want to control the speed of a stepper motor...
Can't.
It's a brushed DC motor driver.
Leo..
ardustar
...R
Ok, I think here is my problem - I thought this thing is a pot when I bought it. seems like it is not. :)
I am using an Uno, cnc shield mwith a A4988 driver and a 17 hS13 motor.
outsider
To adjust the speed of a stepper motor, adjust the time interval between step pulses sent to the driver.
Robin2
#7
Sep 16, 2018, 10:07 am Last Edit: Sep 16, 2018, 10:10 am by Robin2
Then post your program and tell us what extra feature you want to add to it.
Also post a link to the datasheet for the stepper motor.
...R
PS ... I have just seen that you have another Thread about the same problem in which you have been getting the same advice. Don't double Post.
If you click Report to Moderator you can ask to have the two Threads merged
ardustar
Actually that is not the same problem.
Over there I could not get the motor to turn at all, without any speed control.
I don't want to change the speed of the motor using the code, but want to be able to change it while it is in operation using a potentiometer. For this I bought the part mentioned in post one.
but it seems this is not usable as a pot - I just wanted to get info here if I am missing something and this thing is able to be wired to the shield like a pot (3 wires).
So all good, I'll get myself a "real" pot and give it a try.
Robin2
That is completely illogical.
The only thing that can change the speed of the stepper motor is the program code. And the program needs to read the position of the potentiometer and then figure out the interval between steps to create the speed you wish to operate at.
...R
ardustar
...R
Hi R,
I know. I was referring to the post of outsider, which I understood in the way " why use a pot, use the code".
But to change the speed of the motor WITHOUT being connected to the Uno I need a poti - which I thought I had bought, but obviously had not. :)
But a few 3 wire potentiometers just arrived, and I think I will find good use for that PWM controller somewhere.
So thanks to all for trying to help me.
ardustar
Hi there,
I need help again on this topic.
I just realized that the cnc shield on top of my arduino is blocking the analog-in pin for my potentiometer.
Is there a way to connect somewhere on the shield and get the arduino to read that signal?
Robin2
Have you posted a link to the datasheet for the CNC shield?
...R
Wawa
A0-A3 probably go to the Abort/Hold/Resume/E-stop pins (of the white row). The black row is probably ground.
If you don't use those pins, then you can use one of them for your pot.
Leo..
ardustar
@Robin2
No, thnks for reminding me.
I don't know the real manufacturer of the shield, but I found this here:
CNC SHIELD V3.0
Hopefully the information there helps?
