Topic: Connection issue - Bridge library's Process with arduino mega + yun shield (Read 1 time) previous topic - next topic
tonton17
Hardware involved :
  • Arduino Mega 2560 Rev3
  • Genuino Yun Shield
Dear community,
I have a problem that I can't solve after a lot of research.  :smiley-confuse:
I connected my arduino mega with my genuino yun shield (respecting all the procedure). I can upload sketches, everything works fine.
A problem arises when I try to use the Bridge library's Process class to curl data from a web server and get information on the Linux processor (eg : https://www.arduino.cc/en/Tutorial/Process).
When I upload the sketch on the board, I receive the error message below. The red light "user" lights up.
Code: [Select]
com.jcraft.jsch.JSchException: Session.connect: java.net.SocketException: Connection reset
at com.jcraft.jsch.Session.connect(Session.java:557)
at processing.app.NetworkMonitor.open(NetworkMonitor.java:73)
at processing.app.AbstractMonitor.resume(AbstractMonitor.java:110)
at processing.app.Editor.resumeOrCloseSerialMonitor(Editor.java:2231)
at processing.app.Editor.access$2400(Editor.java:77)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2204)
at java.lang.Thread.run(Thread.java:745)
com.jcraft.jsch.JSchException: session is down
at com.jcraft.jsch.Channel.sendChannelOpen(Channel.java:667)
at com.jcraft.jsch.Channel.connect(Channel.java:151)
at com.jcraft.jsch.Channel.connect(Channel.java:145)
at processing.app.NetworkMonitor.tryConnect(NetworkMonitor.java:98)
at processing.app.NetworkMonitor.access$100(NetworkMonitor.java:25)
at processing.app.NetworkMonitor$3.run(NetworkMonitor.java:139)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
And when I try to print something on the console, I receive this message :
Code: [Select]
Connection impossible: new attempt (1)....
Connection impossible: new attempt (2)....
Connection impossible: new attempt (3)....
Connection impossible: new attempt (4)....
Unable to connect: does the sketch use the bridge?
What should I do ? Is there another way to retrieve information on a web server (txt, php, json)?
Many thanks in advance for your help ! :smiley-draw:
tonton17
