Topic: Controlling an Arduino controlling a CNC (Read 672 times) previous topic - next topic
Railroader
After quite some work writing test sketches for stepper motors I look at the next step in order to control my 2 soon digitized milling machines.
Writing dedicated sketches for different CNC operations is one simple way to go. The higher level would be writing G-code and sending it to the Arduino. I see that I need a G-code interpreter installed in my UNOs. Sending the G-code instructions is the next question to solve. Using Serial monitor typing the lines one by one might work as a test but not much more.
Can anyone of You tell me a suitable architecture of the higher level software to achive this?
PaulS
Quote
Google GRBL.
Railroader
So I did. Now I have a grbl folder in the Arduino/library.
Somehow I am supposed to compile the grbl and download it to my UNO.
Started with a new skect, included grbl and compiled. Lots of errors.
The "code" looks like:
Code: [Select]
#include <eeprom.h>
#include <gcode.h>
#include <grbl.h>
#include <jog.h>
#include <limits.h>
#include <motion_control.h>
#include <nuts_bolts.h>
#include <planner.h>
#include <print.h>
#include <probe.h>
#include <protocol.h>
#include <report.h>
#include <serial.h>
#include <settings.h>
#include <spindle_control.h>
#include <stepper.h>
#include <system.h>
I'm missing things…
Can You tell me what?
Railroader
Sorry, I missed some lines.
Trying again:
Code: [Select]
#include <config.h>
#include <coolant_control.h>
#include <cpu_map.h>
#include <defaults.h>
#include <eeprom.h>
#include <gcode.h>
#include <grbl.h>
#include <jog.h>
#include <limits.h>
#include <print.h>
#include <probe.h>
#include <report.h>
#include <serial.h>
#include <system.h>
Railroader
Next try, and it downloads!
Code: [Select]
#include <grbl.h>
How do I proceed?
Railroader
Opening Serial Monitor I read:
Grbl 1.1f ['$' for help]
Typing $ and Cr gives nothing.
Can You tell the next steps?
PaulS
Quote
Post ALL of your code. The code you posted so far does absolutely nothing, and did NOT produce the output that you claim it did.
Railroader
I agree with You, something is wrong.
Compiling that h-file gives the following in the orange error window in the window. Attached below.
I have got into https://github.com/grbl/grbl/wiki/Compiling-Grbl and try to follow it.
Sometimes opening folders doesn't show what the advice tells. Then I'm lost, making desperate tries to make something show up.
Code: [Select]
Archiving built core (caching) in: C:\Users\User\AppData\Local\Temp\arduino_cache_246674\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 30562 bytes (94%) of program storage space. Maximum is 32256 bytes.
Global variables use 1633 bytes (79%) of dynamic memory, leaving 415 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\arduino_build_692663/grblUpload.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\User\AppData\Local\Temp\arduino_build_692663/grblUpload.ino.hex"
avrdude: writing flash (30562 bytes):
Writing | ################################################## | 100% 5.93s
avrdude: 30562 bytes of flash written
avrdude: verifying flash memory against C:\Users\User\AppData\Local\Temp\arduino_build_692663/grblUpload.ino.hex:
avrdude: load data flash data from input file C:\Users\User\AppData\Local\Temp\arduino_build_692663/grblUpload.ino.hex:
avrdude: input file C:\Users\User\AppData\Local\Temp\arduino_build_692663/grblUpload.ino.hex contains 30562 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 4.74s
avrdude: verifying ...
avrdude: 30562 bytes of flash verified
avrdude done.  Thank you.
Railroader
Trying to get forward I have tried to get hold of the grbl code i need to compile and download. I just haven't found that code. I have been exploring Github and grbl advice but I haven't found any opening. There are lots of unrelevant information but where is the piece i need?
PaulS
Quote
You do NOT compile header files. You compile source files that MIGHT include header files.
If you can not compile some code, it is absolutely pointless to claim that that code produced some output.
Railroader
I know, thought it looked strange. I also found ab EEPROM test program in the Grbl folder, compiled and run it. Still I haven't found the code I believe I must compile and download.
Did You read #8?
groundFungus
#11
Sep 24, 2018, 12:19 pm Last Edit: Sep 24, 2018, 12:21 pm by groundFungus
If grbl is properly installed in the sketchbook libraries folder all that you need to do is to go to Files, Examples, grbl and load the grblUpload example then upload the grblUpload file to your Uno.  I that what you did in reply #7?  It is normal to get the low SRAM warning.  Make sure that serial monitor is set to 115200 baud to talk to grbl from the serial monitor.
Quote
There are several programs for sending G code to grbl.  Universal Gcode Sender is one.
How you write the G code is up to you.  You can write the commands in a text file that UGS can send or use a CAM program to generate G code from a drawing.
Railroader
Hi gF!
I guess something is wrong in my installation. It was done a long time ago but never used. In the Arduino library i have folder named grbl. following that I end up with a file like this. There is no grbl folder in the sketch folder.
Code: [Select]
This sketch compiles and uploads Grbl to your 328p-based Arduino!
To use:
- First make sure you have imported Grbl source code into your Arduino
  IDE. There are details on our Github website on how to do this.
- Select your Arduino Board and Serial Port in the Tools drop-down menu.
  NOTE: Grbl only officially supports 328p-based Arduinos, like the Uno.
  Using other boards will likely not work!
- Then just click 'Upload'. That's it!
For advanced users:
  If you'd like to see what else Grbl can do, there are some additional
  options for customization and features you can enable or disable.
  Navigate your file system to where the Arduino IDE has stored the Grbl
  source code files, open the 'config.h' file in your favorite text
  editor. Inside are dozens of feature descriptions and #defines. Simply
  comment or uncomment the #defines or alter their assigned values, save
  your changes, and then click 'Upload' here.
Copyright (c) 2015 Sungeun K. Jeon
Released under the MIT-license. See license.txt for details.
#include <grbl.h>
// Do not alter this file!
Railroader
I Googled on grblupload and fond this on https://github.com/grbl/grbl/blob/master/grbl/main.c.
Modified some main_loop() into loop(), compiled and downloaded it. I don't know much what I have done. Completely wrong?
Code: [Select]
  main.c - An embedded CNC Controller with rs274/ngc (g-code) support Part of Grbl
  Copyright (c) 2011-2015 Sungeun K. Jeon
  Copyright (c) 2009-2011 Simen Svale Skogsrud
  Grbl is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by  the Free Software Foundation,
  either version 3 of the License, or (at your option) any later version.
  Grbl is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for more details.
  You should have received a copy of the GNU General Public License along with Grbl.  If not, see <http://www.gnu.org/licenses/>.
#include "grbl.h"
// Declare system global variable structure
system_t sys;
//int main(void)
  // Initialize system upon power-up.
  serial_init();   // Setup serial baud rate and interrupts
  settings_init(); // Load Grbl settings from EEPROM
  stepper_init();  // Configure stepper pins and interrupt timers
  system_init();   // Configure pinout pins and pin-change interrupt
  memset(&sys, 0, sizeof(system_t));  // Clear all system variables
  sys.abort = true;   // Set abort to complete initialization
  sei(); // Enable interrupts
  // Check for power-up and set system alarm if homing is enabled to force homing cycle
  // by setting Grbl's alarm state. Alarm locks out all g-code commands, including the
  // startup scripts, but allows access to settings and internal commands. Only a homing
  // cycle '$H' or kill alarm locks '$X' will disable the alarm.
  // NOTE: The startup script will run after successful completion of the homing cycle, but
  // not after disabling the alarm locks. Prevents motion startup blocks from crashing into
  // things uncontrollably. Very bad.
  #ifdef HOMING_INIT_LOCK
    if (bit_istrue(settings.flags,BITFLAG_HOMING_ENABLE)) { sys.state = STATE_ALARM; }
  #endif
  // Force Grbl into an ALARM state upon a power-cycle or hard reset.
  #ifdef FORCE_INITIALIZATION_ALARM
  #endif
  // Grbl initialization loop upon power-up or a system abort. For the latter, all processes
  // will return to this loop to be cleanly re-initialized.
  for(;;) {
    // TODO: Separate configure task that require interrupts to be disabled, especially upon
    // a system abort and ensuring any active interrupts are cleanly reset.
    // Reset Grbl primary systems.
    serial_reset_read_buffer(); // Clear serial read buffer
    gc_init(); // Set g-code parser to default state
    spindle_init();
    coolant_init();
    limits_init();
    probe_init();
    plan_reset(); // Clear block buffer and planner variables
    st_reset(); // Clear stepper subsystem variables.
    // Sync cleared gcode and planner positions to current system position.
    plan_sync_position();
    gc_sync_position();
    // Reset system variables.
    sys.abort = false;
    sys_rt_exec_state = 0;
    sys_rt_exec_alarm = 0;
    sys.suspend = false;
    sys.soft_limit = false;
    // Start Grbl main loop. Processes program inputs and executes them.
    protocol_main_loop();
  return 0;   /* Never reached */
/*void setup() {
groundFungus
I have never had any reason to modify the grblUpload sketch.  You are making the grbl installation process way more complicated than it needs to be.
In the IDE.
Go to File, Examples, grbl.
Double click on the grblUpload example to load grblUpload into the IDE.
Click the upload button to install grbl to the Uno.
That's it.
If you modified the grblUpload.ino file, delete the grbl folder from the libraries folder and re-install the library.
You may want to save the config.h file if you made changes to it (for the homing sequence, for instance) and replace the config.h in the new installation with the old one to retain your changes.
