Topic: Uploading a sketch without a computer (Read 707 times) previous topic - next topic
godo
Hello all,
I have the following setup:
- Arduino Mega with custom shield (normal bootloader)
- Development board with a PIC microcontroller and a sketch as hex-file ("PIC-board") in the memory
- three pins (USART + GPIO) of the PIC are connected to RX0, TX0 and Reset of the Mega
- Master computer connected to the PIC-Board
What I need to do is the following:
- The master sends a hex-file to the PIC-board.
- The PIC board acts as if it was a host computer and uploads the sketch to the Mega.
I think it is mostly a question of timing and checking the answers of the Mega-board, and a gifted programmer would probably know where to look for what in the source code of the IDE. Unfortunately, I am not, so I don't. I also do not have to program the necessary code on the PIC-board, but I am supposed to find information about it. If anyone could direct me into the proper direction, I would greatly appreciate it.
Thanks a lot,
Sebastian
PS: the setup is fixed. No other connections possible.
PaulS
Quote
The IDE does not upload the code. It executes a command (avrdude) to do that. There are plenty of places on the internet that document the process of using avrdude to upload a sketch. You will need to make your NOT AN ARDUINO do what avrdude does. How to make your NOT AN ARDUINO do that is NOT AN ARDUINO issue.
kowalski
@godo
I believe that the below topic will give you the help you need.
https://forum.arduino.cc/index.php?topic=505195.0
Cheers!
godo
Right, avrdude! Of course, thank you very much, PaulS!
Also thank you, kowalski, I will take a look at it.
Cheers
Sebastian
