Topic: Whistle detection (Read 4921 times) previous topic - next topic
Celteek
Hello everyone!
I'm working on a robotic project, and I'd like my robot to detect when I whistle. But I'm not that good in electronics... :( Do you know how I can do that? I thought of amplifying the sound with an amplificator and then look for the frequency using the arduino. But is ths possible?
Maybe I should use a frequency-voltage converter? But I want the electronic to be as simple as possible...
Thanks a lot for your help! :)
(Remember I'm a noob :D)
RuggedCircuits
A simple way to do it is with a small microphone and amplifier circuit, like the one on our Gadget Shield or a stand-alone module like this one.
The question is are you just looking for a sound/no-sound decision or are you actually trying to measure the frequency of the whistle and only want to respond to a certain whistle frequency? Selecting a single frequency is a little bit more work, though there have been some Arduino FFT projects recently that can help with this (searching for "Arduino FFT" will give lots of results).
The Rugged Motor Driver: two H-bridges, more power than an L298, fully protected
Big Oil
FYI I tried to hack a small 'lost car-key finder' device that would beep when you whistle, but the thing broke before I could get it to talk to the Arduino.
Grumpy_Mike
#3
Mar 30, 2011, 07:19 pm Last Edit: Mar 30, 2011, 07:21 pm by Grumpy_Mike Reason: 1
There is a chip that will do the whistle detection for you.
The UM3763 contains a signal amplifier and frequency detector and is housed in a small 8 pin package.
Other chips are here:-
http://uk.farnell.com/jsp/search/results.jsp?N=500006+1004414&Ntk=gensearch_001&Ntt=tone+decoder&Ntx=mode+matchallpartial&isGoback=false&displaytext=&isRedirect=false
Celteek
Do you think a LM567 can work?
Magician
Regular piezo buzzer is a whistle detector due it extra nonlinear frequency response.
Probably, operational amplifier thats all you need to get sensitivity level .
Grumpy_Mike
Quote
Yes that would work.
