Topic: how to see serial data in oscilloscope or other equipment? (Read 5669 times) previous topic - next topic
rooney04
Mar 29, 2011, 07:17 pm Last Edit: Mar 29, 2011, 07:21 pm by rooney04 Reason: 1
hi
I did a programming which to sent data serially using arduino uno. my rf module is xbee. so the programming works fine as my receiver arduino(other arduino) able to receive the data. So problem can i use oscilloscpe to see what data sending out? if can how i can  do it?
AWOL
Put your scope probe on your designated serial transmit pin.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
GaryP
...So problem can i use oscilloscpe to see what data sending out? if can how i can  do it?
Do you want to read the data, or just to see bits going by?
Cheers,
Kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
GaryP
Answer to your question is yes. Put your oscilloscopes probes gnd to arduinos gnd, and touch the tip of the probe to arduinos send pin.
Cheers,
Kari
cr0sh
I am curious about one thing - if the OP owns an oscilloscope, but doesn't know how to hook it up, do you think they'll be able to figure out any of the other settings in order to even capture the signal transistions (not to mention that there isn't any info on this scope - does it have enough bandwidth, is it a DSO or analog, etc)?
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
rooney04
i tried to put the probe to my transmitter pin and gnd pin, but still unable get the signal. i m using push buttons as user input. whenever i send a push button it will data . below my programming code. So i want to captured the byte been transferred using oscilloscope. When i pressed the push button, serial monitor showing the data been send but not in the oscilloscope.
int offPin         = 2;
int crankingPin    = 3;
int liftoffPin     = 4;
int upwardPin      = 5;
int downwardPin    = 6;
int turnleftPin    = 7;
int turnrightPin   = 8;
int forwardPin     = 9;
int backwardPin    = 10;
int buttonstate;
// initialize the serial communication:
// initialize the ledPin as an output:
pinMode(crankingPin, INPUT);
pinMode(liftoffPin, INPUT);
pinMode(upwardPin, INPUT);
pinMode(downwardPin, INPUT);
pinMode(turnleftPin, INPUT);
pinMode(turnrightPin, INPUT);
pinMode(forwardPin, INPUT);
pinMode(backwardPin, INPUT);
if(digitalRead(offPin)==HIGH)
  Serial.write('0');
  if(digitalRead(crankingPin)==HIGH)
  Serial.write('1');
if(digitalRead(liftoffPin)==HIGH)
  Serial.write('2');
if(digitalRead(upwardPin)==HIGH)
  Serial.write('3');
  if(digitalRead(downwardPin)==HIGH)
  Serial.write('4');
if(digitalRead(turnleftPin)==HIGH)
  Serial.write('5');
if(digitalRead(turnrightPin)==HIGH)
  Serial.write('6');
  if(digitalRead(forwardPin)==HIGH)
  Serial.write('7');
   if(digitalRead(backwardPin)==HIGH)
  Serial.write('8');
retrolefty
We would have to know more about your specific scope, manufacture and model number. Is it a triggered scope? What you require is to trigger on the falling edge of the send data line, that's when a start bit begins. Your horzontal time base needs to be able to show at least 10 milliseconds for a complete character. The vertical gain should be set to be able to see a 5vdc signal. Knowing how to use a scope takes some study and lots of practice. You are probably better off using a simple program that sends just on character, delays for a second and repeat, and then adust your scope controls to where you see the one complete character once a second on your scope.
Lefty
AWOL
Quote
I'd start simpler, with a square wave of roughly known frequency
Code: [Select]
void loop ()
  digitalWrite (txPin, HIGH);
  delayMicroseconds (100);
  digitalWrite (txPin, LOW);
retrolefty
Quote
Code: [Select]
void loop ()
I'm just not sure he would be able to get or know if his scope triggering is adjusted correctly with continuous pulses, that's why I suggested the single character per second. Heck, I don't even know if he has a analog or digital scope, and without more feedback from him I think I'll bow out for now.  ;)
GaryP
The first thing here is to learn the scope, then test the arduino...
I think we are trying to solve wrong problem.
Cheers,
Kari
zeroneo
Unless you have a good oscilloscope, it will be very hard to capture the data (although new models, even for low end, are starting to include a serial translate mode). Honestly, unless you are using borrowed equipment, as you do not seem to be very familiar with oscilloscopes I doubt you'll be able to use for debugging. Instead get a logic analyser, if you don't have the money to get a proper one just go to ebay and get a cheap know off. They are pretty much a USB transmitter and use your PC for all the processing, and yes, most of them are nothing more than toys, but it'll do the job at not very high speeds. If you have a litter bit more money I would recommend the Open Logic Sniffer, specially on top of the salea logic analyser since you get more hackable hardware for your money.
