Loading...
Pages: [1]   Go Down
Author Topic: Using Visual Basic or another GUI  (Read 1084 times)
Offline Offline
Newbie
View Profile
I have an arduino uno. I'm using it for a school project in engineering. We are challeneged with designing a handle that sends a signal via usb. That's why we chose the arduino uno. We would like to physically show the signal change with a dot or something that changes color when a button is pushed and show it moving when the handle rotates. Could someone please help me in programming the arduino in visual basic?
Thanks
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
You can't program an Arduinoi in VB.
Sorry.
C/C++ is the only option.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
There's no way possible of using VB or some other GUI with the arduino?
I know I've seen some code out there but I just want to understand it. I'm not a computer programmer, just a mechanical engineer so I'm confused about the arduino ide and VB.
Please help!!
Logged
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
Please help!!
Visual Basic is a programming IDE that runs on a PC and one develops PC programs with it that can only run on PC hardware. The Arduino IDE is a C/C++ programming IDE that generates code for the Atmel AVR series controller chips and the completed program is uploaded to run on the Arduino board.
Now if you have a Arduino application where it's running program communicates with the PC, then one could use Visual Basic to write the PC program that would receive and send that data to and from the sketch program running on the Arduino board.
You need to stay your requirements better to see if there is a need to use Visual Basic at all.
Lefty
Logged
Espoo, Finland
Offline Offline
God Member
"Oops, try again..."
View Profile
You can make a VB program that communicates with programmed arduino.
Cheers,
Kari
Logged
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
There is the Netduino, can that run VB?
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Port Elizabeth, South Africa
Offline Offline
Newbie
Arduino user South Africa
View Profile
WWW
Tru this, not sure if it will work with Netduino.
Logged
Offline Offline
Newbie
View Profile
WWW
Or/And  you can use Processing for the Graphical Part of your Project:
http://www.processing.org/
Logged
Leeds, UK
Offline Offline
Full Member
View Profile
WWW
If you just want to use the Visual Basic IDE to develop in however, you might want to take a look at Visual Micro - it allows you to use Visual Studio to code in instead of the Arduino IDE.
Logged
Pages: [1]   Go Up
Print
Jump to:
