Topic: Joystick controller USB interface (Read 555 times) previous topic - next topic
leejones15
Hi folks,
I have a Turnigy 5x controller that I would like to hook up to my PC so that I can use it with a flight simulator.
I've tried out UnoJoy, but the main file uses analog for the thumbsticks, but mine returns PWM values.  I found one example that uses PWM, but it is for a controller than packages all the sticks into a single PWN output.  My controller sends individual signals for each axis and stick (so 4 outputs/inputs instead of one from the previous tutorial).
I've arduino experienced, but not very code saavy, so this is out of my own problem-solving capabilities.  If anyone has done this before, or can offer up a code that I can try, I would appreciate the help.
TIA
Code: [Select]
#include "UnoJoy.h"
bool FirstLoop;
dataForController_t controllerData;
#define PPM_Pin 3   // Pin of PPM Input. Must be 2 or 3
int ppm[16];        // array for storing up to 16 servo signals
void setup(){
  setupUnoJoy();
  FirstLoop = true;
  pinMode(PPM_Pin, INPUT);
  attachInterrupt(PPM_Pin - 2, read_ppm, CHANGE);
  TCCR1A = 0;  //reset timer1
  TCCR1B = 0;
  TCCR1B |= (1 << CS11);  //set timer1 to increment every 0,5 us
void loop(){
  if(FirstLoop == true) {
    controllerData = getControllerData();
    FirstLoop = false;
  controllerData.leftStickX = map(ppm[0], 990, 2010, 0, 255);
  controllerData.leftStickY = map(ppm[1], 990, 2010, 0, 255);
  controllerData.rightStickX = map(ppm[2], 990, 2010, 0, 255);
  controllerData.rightStickY = map(ppm[3], 990, 2010, 0, 255);
  setControllerData(controllerData);
dataForController_t getControllerData(void){
  dataForController_t controllerData = getBlankDataForController();
  controllerData.triangleOn = 0;
  controllerData.circleOn = 0;
  controllerData.squareOn = 0;
  controllerData.crossOn = 0;
  controllerData.dpadUpOn = 0;
  controllerData.dpadDownOn = 0;
  controllerData.dpadLeftOn = 0;
  controllerData.dpadRightOn = 0;
  controllerData.l1On = 0;
  controllerData.r1On = 0;
  controllerData.selectOn = 0;
  controllerData.startOn = 0;
  controllerData.homeOn = 0;
  controllerData.leftStickX = 0;
  controllerData.leftStickY = 0;
  controllerData.rightStickX = 0;
  controllerData.rightStickY = 0;
  return controllerData;
void read_ppm(){  //leave this alone
  static unsigned int pulse;
  static unsigned long counter;
  static byte channel;
  counter = TCNT1;
  TCNT1 = 0;
  if(counter < 1020){  //must be a pulse if less than 510us
    pulse = counter;
  else if(counter > 3820){  //sync pulses over 1910us
    channel = 0;
  else{  //servo values between 510us and 2420us will end up here
    ppm[channel] = (counter + pulse)/2;
    channel++;
