Topic: quick question, would this work? (Read 513 times) previous topic - next topic
andrewcat12
im trying to make my circuit more compact so i dont wanna use one of those bulky 5v to 3v3 adapters
BJHenry
No. Your Nano has a 3.3V output, try using that to power the NRF24L01. I've done just that (using Nanos with a CH340). Robotdyn also make a Nano with a more powerful 3.3V regulator that might be able to power the NRF24L01 a bit better.
MarkT
Power inputs to devices must be regulated power, any kind of resistive dropping will not
give a stable voltage and everything will misbehave.
andrewcat12
ill try but i heard the 3v3 output didnt have enough current to supply the nrf24?
DrAzzy
That may well be an issue.
You *cannot* use a resistor, as the current drawn by the NRF24 varies from near zero to... quite a bit more... depending on what it's doing. A resistor that provided 3.3v at peak current would leave almost 5v on the NRF24 when it wasn't drawing much current.
You must use a regulator - a 1117-series regulator in TO-220, with ceramic caps soldered right onto the leads, is probably the most compact solution.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
Wawa
A Nano gets it's 3.3volt from the USB<>serial chip,
The Nano clone I have (CH340 chip) can provide 30mA without collapsing.
It seems that the nRF24 is happy with 15mA.
Leo..
andrewcat12
i think this is what i prefer out of all the solutions, ill research into this, thanks
BJHenry
It is definitely worth a try. I've heard some people that have trouble with it, but as I said before it works for me.
PaulRB
I've heard of people having trouble with esp-01 WiFi modules powered through Nano's 3.3V. And no wonder, it's much more power hungry than nrf24. But the two look very similar to a beginner.
polymorph
You realize... everyone here has a "quick question", and wants to know "if it will work".
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
andrewcat12
think thats what forums are for
Wawa
I think the 3.3volt pin just lacks the buffer caps to power a transmitter that uses high current pulses.
I frequently power an ESP8266 module (80mA) from an Uno clone (150mA) to flash, but you DO need a (>=470uF) buffercap on that power line. Because the ESP draws ~400mA during the short transmit pulses.
Leo..
DrAzzy
What hes saying is you should use a topic title that better describes the issue you're having in the future - that way people who know the answer can more easily find you
MarkT
And others with the same problem can find the answer too...
polymorph
#14
Sep 23, 2018, 09:50 pm Last Edit: Sep 23, 2018, 09:52 pm by polymorph
Yes, that is what I mean. Imagine everyone titled their questions the same way:
Help me, I need help
Help me with this
I am at a loss, please help me
Quick question, will this work
How does this work
Help me make this work
There is a sticky post at the top of every section of the forum:
How to use this forum - please read.
