« on: March 29, 2011, 04:40:42 pm » |
Hi guys, been working on a little project for a couple of weeks now, essentially, a solar powered chicken coop door opener. I was using a standard DPDT relay for this, and it was going mostly fine, but then I began to think about the power required to keep the relay in its open position and decided to swap it out for a latching relay instead. Here is the datasheet for my relay: http://www.datasheetarchive.com/RSBL-12-S*-datasheet.html (second one down) It has 2 coils, not the standard 1, and i'm trying to get this working with my arduino standalone board (on the same breadboard) and it's just not working. I originally had the relay wired up as shown here: http://www.arduino.cc/playground/uploads/Main/relays.pdf which worked fine, however, after adding in the new relay, I simply added in another transistor/diode module for controlling the other coil, but it's not clicking in either direction, what am I doing wrong? Many thanks!
« Reply #1 on: March 29, 2011, 04:58:44 pm » |
Here's my code, the digitalWrite(LEDpin) parts are probably wrong, since I haven't been able to test it out yet. Tell me what you guys think  int LDR_pin = 0; // analog pin 0 (connect LDR here)
int LDR_val = 0; //initial LDR value
int LEDpin = 13; //This is the relays coil 1
int LEDpin2 = 12; //This is the relay
int counterclose = 0; //counter for closing validation
int counteropen = 0; //counter for opening validation
int Delay1 = 2;
int Delay2 = 2;
int TestEnablePin = 4; //connected to switch saying if the test mode is enabled, if yes, delay is much shorter int TestEnable = 0;
int threshold = 200; // a threshold to decide when the relay turns on
void setup(){
// declaration of pin modes
pinMode(LDR_pin, INPUT);
pinMode(LEDpin, OUTPUT); pinMode(LEDpin2, OUTPUT);
pinMode(TestEnablePin, INPUT);
// begin sending over serial port
void loop(){ TestEnable = digitalRead(TestEnablePin);
// read the value on analog input
LDR_val = analogRead(LDR_pin);
if (TestEnable == HIGH) { Delay1 = 2; Delay2 = 2; } else { Delay1 = 1200; Delay2 = 1200; }
// if value greater than threshold turn on LED
if (LDR_val < threshold) counterclose = counterclose+1; else counterclose = 0;
if (counterclose > (Delay1))//set delay here, 1 loop = 1 second digitalWrite(LEDpin2, HIGH); delay(100); digitalWrite(LEDpin2, LOW);
if (LDR_val > threshold) counteropen = counteropen+1; else counteropen = 0;
if (counteropen > (Delay2))//set delay here, 1 loop = 1 second digitalWrite(LEDpin, HIGH); delay(100); digitalWrite(LEDpin, LOW);
// output 'LDR_val' value into the console
Serial.print("LDR = "); Serial.print(LDR_val);
Serial.print(" Counter close = "); Serial.print(counterclose);
Serial.print(" Counter open = "); Serial.print(counteropen);
Serial.print(" testpin = "); Serial.print(TestEnable);
Serial.print(" Delay1 = "); Serial.print(Delay1);
nr Bundaberg, Australia
« Reply #2 on: March 29, 2011, 06:55:53 pm » |
This probably doesn't do what you think, add {} around the three lines that I guess are supposed to be inside the if(). Same on the next if(). delay (100) is 10th of a second. Are the two pins driving transistors? _____ Rob
« Reply #3 on: March 29, 2011, 07:05:37 pm » |
Yep, the 2 pins are connected to transistors. I wasn't actually using this code, I'm using the blink example at the moment, as in set pin 13 high, wait 1 second, set pin 13 low, wait 1 second, set pin 12 high, wait, set pin 12 low, etc, but i still can't get it to click.
I've attached an image below of how i'm connecting the relay up.
Massachusetts, USA
« Reply #4 on: March 29, 2011, 07:12:58 pm » |
Where are you getting the 12 volts for your RSBL-12-S relay?
« Reply #5 on: March 29, 2011, 07:16:18 pm » |
At the moment, that sketch isn't strictly true, the rails going around are +5v and ground respectively, as these go from a regulator as the power supply for the atmega328 chip which is on the same breadboard. The power for the relay is being provided by a 9v battery (definately clicks the relay, also works with other 12v relays), and i have ground from the right leg of the transistor going to 9v ground, and arduino ground.
« Reply #6 on: March 29, 2011, 07:28:57 pm » |
SOLVED!! Turns out, the transistors were duff. Whoops
« Reply #7 on: March 29, 2011, 07:39:56 pm » |
Ok, now the relay's-a-tickin' what do I need to do to the code to make it only set pins 12 or 13 to high if they are not already?
The way it is at the moment, it detects light, once the counter fills up, clicks the relay, then keeps counting, and for every loop it goes around continues pulsing the relay. I just want it to click itself on, then stay like that, unless the LDR value drops back below the threshold again, in which case, it flips it.
« Reply #8 on: March 29, 2011, 07:44:31 pm » |
Keep a status variable that tells you what state the relay is in, then test that before writing to the pin
if( should_set_relay() && relay_status != SET) digitalWrite (setPin, HIGH)
______ Rob
« Reply #9 on: March 29, 2011, 07:49:31 pm » |
Ok, so it's a boolean variable or a sting variable or doesn't it really matter? I take it I can just set the variable to begin with, say set it closed to begin with, then have the variable shouldBe set to closed too, until counteropen becomes greater than delay2? Where abouts in the code should these be? I'm a terrible coder, but getting there... slowly...
« Reply #10 on: March 30, 2011, 11:56:39 am » |
Ok, had a crack at the code again, see what you guys think: int LDR_pin = 0; // analog pin 0 (connect LDR here)
int LEDpin2 = 12; //This is the relay coil 2
int Delay1 = 2;
int Delay2 = 2;
boolean relayState = false; boolean relayShouldBe = false;
int threshold = 80; // a threshold to decide when the relay turns on
void setup(){
if (counterclose > (Delay1)){ relayShouldBe = false; }
if (counteropen > (Delay2)){//set delay here, 1 loop = 1 second relayShouldBe = true; }
if (relayShouldBe == false && relayState == true){ digitalWrite(LEDpin, HIGH); delay(100); digitalWrite(LEDpin, LOW); }
if (relayShouldBe == true && relayState == false){ digitalWrite(LEDpin2, HIGH); delay(100); digitalWrite(LEDpin2, LOW); }
Manchester (England England)
Online
Solder is electric glue
« Reply #11 on: March 30, 2011, 03:59:18 pm » |
Turns out, the transistors were duff. Did you kill them? There is no base resistors in that diagram. that sketch isn't strictly true, Then neither can our answers be. Ok, had a crack at the code again, see what you guys think So what does it actually do?
« Reply #12 on: March 30, 2011, 05:55:55 pm » |
I had used the transistors previously without base resistors in a different circuit, I must have fried them then. The sketch was just a simplified drawing of what I was trying to do (with a 390 ohm resistor to the base  ), you get the general idea, the transistors actually get their power from the same battery (about 10v) which powers the rest of the circuit, with the ground and +5v rails being connected to the arduino and anything else which requires 5 volts. The code should monitor the LDR for its value, if it's above the threshold value which is preset in the code, it starts incrementing a counter (counteropen), which once that goes above a certain value (delay1) it clicks the relay on which should power the motor so it can open a chicken coop door. The same applies in reverse. The delay is both for validation and to make sure the chickens would definitely be inside the coop when it closes. Make sense to you? Any more questions, feel free to ask
Online
« Reply #13 on: March 31, 2011, 05:37:46 pm » |
The sketch was just a simplified drawing of what I was trying to do The problem is that in electronics a schematic is supposed to be what you are doing. How can we tell if you have missed something out in your implementation or just on the drawing. That sounds fine but I would :- 1) loop until the LDR reading goes above the threshold. 2) Set a time for how long you want it to be this before the opening using openTime = millsi() + myDelay; 3) If the LDR drops below this then reset openTime. 4) when openTime exceeds the current time given by millis(); fire the relay.
