Pages: 1 [2]   Go Down
Author Topic: ATMEGA 644 won´t work with WIZNET5100 WIZ812MJ  (Read 2104 times)
NZ
Turtle in a hard shell
Did you have any luck with this in the end?
I have just received the prototype boards back from the printer and have populated them, and am now just attempting to get some test code working for the Wiznet module.
I dont have the exact computer setup I had when I did my first test, so I have started again with IDE 22.
I have downloaded the arduino-extras zip file that Mark S produced on his website (www.avr-developers.com) as that has the core files for the 644P.
I compared them against the Sanguino files and there are decrepencies. I couldnt even get the Sanguino core files to compile the Ethernet library.
I then looked in the pins_arduino.h (and .c) files, and found there was no reference to the MISO, MOSI, CSK, SS for the 644P configuration, as it looks like the SPI library uses these variable declarations.
here are some examples:
In the SPI library, it has the following code:
void SPIClass::begin() {
  // Set direction register for SCK and MOSI pin.
  // MISO pin automatically overrides to INPUT.
  // When the SS pin is set as OUTPUT, it can be used as
  // a general purpose output port (it doesn't influence
  // SPI operations).
  pinMode(SCK, OUTPUT);
  pinMode(MOSI, OUTPUT);
  pinMode(SS, OUTPUT);
  digitalWrite(SCK, LOW);
  digitalWrite(MOSI, LOW);
  digitalWrite(SS, HIGH);
It refers to the SCK, MOSI and SS variables.
I then looked in the pins_arduino files in the modified core files from Mark S, and found this entry in the pins_arduino.h file:
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
const static uint8_t SS   = 53;
const static uint8_t MOSI = 51;
const static uint8_t MISO = 50;
const static uint8_t SCK  = 52;
#else
const static uint8_t SS   = 10;
const static uint8_t MOSI = 11;
const static uint8_t MISO = 12;
const static uint8_t SCK  = 13;
#endif
It didn't have any listing for the 644P.
I added in this part, however still no joy:
#elif defined(__AVR_ATmega644__) || defined(__AVR_ATmega644P__)
const static uint8_t SS   = 30;
const static uint8_t MOSI = 5;
const static uint8_t MISO = 6;
const static uint8_t SCK  = 7;
SS = 30 above is how I have the Ethernet Board wired in my setup. Very crude way to do it, as all SPI devices would therefore use this, however I dont see the SPI library as being very accomidating for this anyway, as the SS is hardcoded inside the library. I am not experienced enough to know the best method to make the SPI library suitable for using multiple SPI devices at once.
Either way, I have hard coded my SS to be 30 at the moment, so I am guessing that the SPI library will therefore use this value of 30.
But as mentioned, still no joy yet.
I really cannot recall how I got it working when I did my first testing, and am now actually starting to doubt if I did infact carry out this testing on the 644P...
My memory is quite poor.
If anyone has any input I would love to hear.
I have already emailed Mark to see if he can assist.
Thanks
NZ
I have had a bit more of a look, trying to understand how this works.
In the Ethernet Library, there is the W5100 files that refer to the SPI.h file. So I am assuming this is the link that joins the Ethernet library to the SPI library.
Inside this file, near the bottom are the following lines, and I think these may be related to the problem, if not the cause (additional to the already mentioned).
private:
  inline static void initSS()    { DDRB  |=  _BV(4); };
  inline static void setSS()     { PORTB &= ~_BV(4); };
  inline static void resetSS()   { PORTB |=  _BV(4); };
#else
  inline static void initSS()    { DDRB  |=  _BV(2); };
  inline static void setSS()     { PORTB &= ~_BV(2); };
  inline static void resetSS()   { PORTB |=  _BV(2); };
#endif
I am not yet sure what to put here for the 644 and 644P, however I will give it some thought. I think its currently trying to do something incorrect with the SS bit, so a new number needs to be inserted instead of 2 or 4 above in a new #elif statement. I am not sure what that is at this point though, not code that I have had to try and interpret before.
NZ
Actually, I think the value in your case should be 16.
In my case, because I am not using a standard SS pin (using Digital 30, or PA1), mine should be 2 - but of PortA.
16 in Binary when mapped to Port B, is PB4 which is the SS pin.
2 in Binary when mapped to Port A, is PA1 which is my custom SS pin.
INCORRECT ABOVE SO EDITED:
Digital 30 for me is PA1, which is _BV(1), not 2 as mentioned above.
PB4 for you, which is _BV(4), not 16 as mentioned above.
I will test this once I have given my son his bath etc - smiley Hopefully this is all that is required.
So you maybe need to do this:
EDITED BELOW TOO
private:
#else
#endif
and I need to try this:
private:
  inline static void initSS()    { DDRA  |=  _BV(1); };
  inline static void setSS()     { PORTA &= ~_BV(1); };
  inline static void resetSS()   { PORTA |=  _BV(1); };
#else
#endif
Time will tell
Cheers
James
« Last Edit: April 20, 2011, 05:41:52 pm by WanaGo » Logged
NZ
Ok no that didnt work.
SF Bay Area (USA)
Strongly opinionated, but not official!
The _BV(n) syntax converts a "bit number" to a binary value, and since the AVR is an 8 bit architecture, it won't ever be more than 7 for accessing bits in an IO port.   The actual definition is:
#define _BV(n) (1<<(n))
So for PB4 (which is a bit number as well), you should try:
inline static void initSS()    { DDRB  |=  _BV(PB4); };
and for PA1 you can use
inline static void initSS()    { DDRA  |=  _BV(PA1); };
NZ
Thanks Westfw,
I will try that, but I am not that hopeful to be honest.
It does make sense what you said, however I think the value for mine will still end up as 2, correct? PA1 is the 2nd bit in the port. EDITED - Should be 1
And that didnt seem to work (for 2 above).
It is strange how this library doesnt actually use the defined SS pin mapping that is found in the pins_arduino file, it does it all over again here with those direct methods. The SPI library utilises the pins_arduino mapping, and this library uses the SPI library but doesnt utilise them. I really dont know what I am talking about though, this is all quite new to me, I am amazed I have gotten this far.
Is anyone please able to assist in getting this to work? Its not just the 644 and 644P that are suffering, it will be all 'non arduino' processors that havent had the code tailored to suit. If we can figure out what is required, then it will no doubt help a number of people.
Thanks
« Last Edit: April 20, 2011, 05:43:00 pm by WanaGo » Logged
SF Bay Area (USA)
The definition of "SS" in pins_arduino.h didn't happen until version 0019, which is probably well after the library was written.
NZ
This is true.
I will do some more testing in about an hour.
Thanks
NZ
D:\Arduino\arduino-0022\libraries\Ethernet\utility/w5100.h:316: error: 'PA1' was not declared in this scope
NZ
Gaa - just spotted an error I made above.
PA1 is the 2nd bit, therefore is 1, not 2. Starts at 0. My bad.
Spotted that when looking at the pins_arduino code that Mark wrote.
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] =
_BV(0), /* 0, port B */
_BV(1),
_BV(2),
_BV(3),
_BV(4),
_BV(5),
_BV(6),
_BV(7),
_BV(0), /* 8, port D */
_BV(1),
_BV(2),
_BV(3),
_BV(4),
_BV(5),
_BV(6),
_BV(7),
_BV(0), /* 16, port C */
_BV(1),
_BV(2),
_BV(3),
_BV(4),
_BV(5),
_BV(6),
_BV(7),
_BV(7), /* 24, port A */
_BV(6),
_BV(5),
_BV(4),
_BV(3),
_BV(2),
_BV(1),
_BV(0)
I will try this tonight.
Edited posts above and used strike through so old text can still be read so they still flow.
« Last Edit: April 20, 2011, 05:43:54 pm by WanaGo » Logged
NZ
Gaa didnt work... but I think I still have the BV value wrong.
Looked down the file a bit and saw I had it wrong.
NOT_ON_TIMER,   /* 24 - PA0 */
NOT_ON_TIMER,   /* 25 - PA1 */
NOT_ON_TIMER,   /* 26 - PA2 */
NOT_ON_TIMER,   /* 27 - PA3 */
NOT_ON_TIMER,   /* 28 - PA4 */
NOT_ON_TIMER,   /* 29 - PA5 */
NOT_ON_TIMER,   /* 30 - PA6 */
NOT_ON_TIMER   /* 31 - PA7 */
So PA1 is therefore _BV(6)...
But sadly it didnt work....  smiley-cry
NZ
Still stuck on this if anyone has any desire to assist...
Thanks
SF Bay Area (USA)
How are you getting THAT?
Px1 should always be _BV(1); the file you were quoting has info on mapping the Arduino "pin numbers" to ports and bits, which is entirely different...  The general process for "direct port IO" is:
1) figure out which arduino/whatever "pin" you want to use.
2) Look at pins_arduino.* to figure out which "port" and "bit"  (or "mask") you need to use.
3) if necessary, convert the "bit number" to a "mask" by using _BV()
Your "not on timer" array that says (in the comment) that pin 30 is PA6 does not match the digital_pin_to_bit_mask that says (in CODE) that pin 30 is PA1.  When in doubt, trust the code.
NZ
Hi Westfw,
You are right, what I posted was confusing.
I am basing all this stuff on the pins_arduino file from Mark S's core files. the pins_arduino file references a pins_duino644.cxx extension file specific for the 644(P).
Basically those arrays are what I am getting the BV value from. Not the content so much, but I assume the order of the 3 arrays are sequentially the same as each other.
When I look at all three of them:
const uint8_t PROGMEM digital_pin_to_port_PGM[] =
PB, /* 0 */
PB,
PB,
PB,
PB,
PB,
PB,
PB,
PD, /* 8 */
PD,
PD,
PD,
PD,
PD,
PD,
PD,
PC, /* 16 */
PC,
PC,
PC,
PC,
PC,
   PC,
PC,
PA, /* 24 */
PA,
PA,
PA,
PA,
PA,
PA,
PA  /* 31 */
_BV(1),
_BV(2),
_BV(3),
_BV(4),
_BV(5),
_BV(6),
_BV(7),
_BV(1),
_BV(2),
_BV(3),
_BV(4),
_BV(5),
_BV(6),
_BV(7),
_BV(1),
_BV(2),
_BV(3),
_BV(4),
_BV(5),
_BV(6),
_BV(7),
_BV(6),
_BV(5),
_BV(4),
_BV(3),
_BV(2),
_BV(1),
_BV(0)
const uint8_t PROGMEM digital_pin_to_timer_PGM[] =
NOT_ON_TIMER, /* 0  - PB0 */
NOT_ON_TIMER, /* 1  - PB1 */
NOT_ON_TIMER, /* 2  - PB2 */
TIMER0A,     /* 3  - PB3 */
TIMER0B, /* 4  - PB4 */
NOT_ON_TIMER, /* 5  - PB5 */
NOT_ON_TIMER, /* 6  - PB6 */
NOT_ON_TIMER, /* 7  - PB7 */
NOT_ON_TIMER, /* 8  - PD0 */
NOT_ON_TIMER, /* 9  - PD1 */
NOT_ON_TIMER, /* 10 - PD2 */
NOT_ON_TIMER, /* 11 - PD3 */
TIMER1B,     /* 12 - PD4 */
TIMER1A,     /* 13 - PD5 */
TIMER2B,     /* 14 - PD6 */
TIMER2A,     /* 15 - PD7 */
NOT_ON_TIMER, /* 16 - PC0 */
NOT_ON_TIMER,   /* 17 - PC1 */
NOT_ON_TIMER,   /* 18 - PC2 */
NOT_ON_TIMER,   /* 19 - PC3 */
NOT_ON_TIMER,   /* 20 - PC4 */
NOT_ON_TIMER,   /* 21 - PC5 */
NOT_ON_TIMER,   /* 22 - PC6 */
NOT_ON_TIMER,   /* 23 - PC7 */
The bottom array set has coments, suggesting PA1 is the 25th (well actually 26th as its starting from 0, but has 25 next to it) item in that list. Looking above in the 2nd array, the 25th item is _BV(6).
That is what I based it on.
Is that a stupid assumption?
I dont understand what the arrays actually do, and how the first array especially works. Anyway, that is detail I most likely dont need to know at this stage.
I have a feeling the issue I am having is with the Ethernet library, rather than the core files, as Mark S has had SPI devices running fine on the 644P.
It is however in the Ethernet library that I utilise the _BV(6), in the w5100.h file.
private:
#elif defined(__AVR_ATmega644__) || defined(__AVR_ATmega644P__) || defined(__AVR_ATmega1284P__)
  inline static void initSS()    { DDRA  |=  _BV(6); };
  inline static void setSS()     { PORTA &= ~_BV(6); };
  inline static void resetSS()   { PORTA |=  _BV(6); };
#else
#endif
Any suggestions.
I am not experienced enough to really know what I am doing. Well, I am making guesses, which I dont think is the appropriate way to really resolve this.
Thanks
« Last Edit: April 25, 2011, 10:45:05 pm by WanaGo » Logged
Pages: 1 [2]   Go Up
