Topic: A problem when importing 3rd-party libraries (Read 743 times) previous topic - next topic
WZTong
I want to write my skech on "https://create.arduino.cc/editor/" and my project need a library called SCoop, but it can't be found by the search, so I downloaded a .zip file on the github and was successful importing it into my custom lib, but I still can't Verify my sketch for "No such a file" reason. I want to know how to solve this problem.
ballscrewbob
#1
Sep 23, 2018, 06:02 pm Last Edit: Sep 23, 2018, 06:03 pm by ballscrewbob
Some third party libraries might not import correctly as they may contain things the editor does not like.
Attached a help file for importing libs and sketches.
There may also still be a folder depth limit in CREATE so sometimes you may need to remove excess folders.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
WZTong
I don't think I did sth wrong so can u just help me zip this libraries into the form I can directly import?
SCoop library: https://github.com/fabriceo/SCoop
ballscrewbob
I probably could do the work for you but then you would not have learned anything.
May I suggest you use the help file provided and come back when you are actually stuck with doing that.
Noticed also from your other post you may be using ESP8266 so I must ask what board this problem is actually with ?
WZTong
Sorry for a long-playing scilence! And thank u for ur consideration!
Now I deleted some files (leave only 1 library I need) and things goes like this but still can't work.
SCoop.zip
>SCoop
>>examples
>>keywords.txt
>>SCoop.cpp
>>SCoop.h
(I attached the zip I imported below)
Just Aruino UNO used in the project!
ballscrewbob
#5
Sep 30, 2018, 01:23 am Last Edit: Sep 30, 2018, 01:25 am by ballscrewbob
The original files import perfectly from your github link.
They show up in CREATE just fine.
Almost all the examples compile just fine apart from 3 in the whole range of examples and they throw an ARM/AVR type error and refer back to the Arduino forum but nowhere in particular !
It might be better if you contacted the author on GITHUB as I also noticed many parts are over 6 years old !
EDIT here is the authors original post about the lib
WZTong
The original files import perfectly from github link.
But still can't find SCoop.h
I think it's because this lib is already mature(actually it is I think). So there is no need to update it.
Can u just upload the zip which can work properly? I WILL check the diffrence and find why. (I think this can help me in a more direct way since I don't have enough time to read such a long .pdf)
ballscrewbob
As I already said the original link you gave imports just fine !
Nobody ever did my work for me.
If you are not prepared to help yourself by doing some reading at the very least then I don't see any point in trying to help further.
WZTong
Tried again
I can see the success info and can click INCLUDE botton and can even see the comment
// SCoop - Version: Latest
added, but can't access the complier still.
Is this problem about the policy that in my country I can't upload it well(CN)?
ballscrewbob
I am unsure about it being your internet connection in China ?
However CREATE does also work with most VPN's if you have access to one ?
Also unsure what you actually mean by access to the compiler so if you could give more detail.
Can you compile any of the example sketches ?
WZTong
No I can't complie any sketches.
I think this can explain my situation well:
https://www.youtube.com/watch?v=ePRTo8p-vLM&feature=youtu.be
ballscrewbob
OK your video shows a "WINDOWS" screen and NOT a Chromebook device.
Please what are you actually using as your OS and browser ?
In your other post you state CHROME CORE did you just mean CHROME BROWSER ?
WZTong
It's windows system and now it's none of the Browser's problem since I've change it into Chrome itself.
But problems still happening:
 https://www.youtube.com/watch?v=9K-E0ZYaP6o&feature=youtu.be
ballscrewbob
#13
Oct 03, 2018, 02:46 pm Last Edit: Oct 03, 2018, 02:47 pm by ballscrewbob
Could you please try again but follow the steps below.
1. Open CREATE normally.
2. Remove the scoop lib from your custom libs.
3. Refresh the CREATE editor page.
4. Right click on the CREATE taskbar ICON and select "Open DEBUG Console"
   An almost blank web page will open and you should leave it open for the moment.
5. Go to the CREATE editor page and import your lib without any changes to it.
6. After the error shows up open the DEBUG page.
7. COPY AND PASTE that content back here but ENSURE you use CODE TAGS ( </> )
8. Close the debug web page
Maybe the log will show something as we have not yet been able to re-create the problem.
matteosuppo
It was an error on our end. It should be solved now. Can you confirm?
http://www.google.it
