Topic: RFID! (Read 878 times) previous topic - next topic
TrevorB
Quick one,
As I am awaiting delivery from a couple of max7219 chips I thought I would look at rfid, I did a little research and noticed sparkfun did one. But they charge quite a bit of money for one. I checked good o'ld eBay and found this http://www.ebay.co.uk/itm/RFID-13-56Mhz-Module-Tags-SPI-Interface-Read-Write-for-Arduino-UNO-R3-Mega-MCU-/170947354322?pt=UK_Computing_Other_Computing_Networking&hash=item27cd419ed2 its perfect price point. but I am not so good on the programming side and was wondering if there is a similar one that has a library so I can interface it with hopefully my computer! Thank you for reading and see you soon
Trevor Boultwood
TrevorB
pylon
Your ebay page links to Arduino sample code. What else do you expect?
I don't know the module and don't know if it works but you seldom get that much Arduino support on ebay.
TrevorB
Sorry frind,
My email was rushed yesterday. here is the link I mean to to send:
I would like to easily control or read the information. and the sample code is very hard for beginners. I was wondering if there were any libraries to simplify the process to start of. Thank you for your reply.
Trevor Boultwood
TrevorB
pylon
The sample code is a library although it doesn't come in that format. Just split the file up and place the setup() and loop() routines in a separate file and you have a library.
To start, just uncomment the Serial.println() in lines 186-196 and you get the serial number of every tag the reader get a hold of. What more do you need to start?
tkbyd
No promises... but at that price, I'd certainly give it a try, if I were you.
The following code... library-less... would probably need very little adapation, if any...
http://sheepdogguides.com/arduino/art3rfid1.htm
For the beginner, libraries are a mixed blessing. They have their place... but should be used in moderation!
