Topic: Beginner Buzzer Question (Read 2275 times) previous topic - next topic
Schlangy
Hi Everyone,
     I'm new to arduino and finished going through some of the beginner tutorials.
I tried hooking up a buzzer to my arduino and couldn't get it to make a sound.
The Buzzer is a model 273-055 from Radio Shack. The description says it operates on 12VDC and delivers 75dB at 15mA maximum current.
I had the red wire running into the Ground port on the arduino, and the black wire first hitting a 1k Ohm resistor and then going into the 5V
port on the arduino.
What am I doing wrong?
Thanks
MarkT
Firstly its a 12V buzzer.  Secondly red is positive, black is negative.  Thirdly what current does it take?
Big Oil
The arduino only has 5 volts max.  There are 5 volt buzzers at radio shack, so I'd get another one.
Schlangy
Big Oil, alright I'll go pick up a 5 volt buzzer.
But is there a way to get the 12v buzzer to work with the arduino?
Big Oil
Yes.  You will need:
12v battery or a 12 volt dc power adapter (some 12v power supply)
An NPN transistor.
In case you don't know how a transistor works, it's basically a light switch that you turn on with the arduino.  You don't have the power going into the arduino, over 9 volts can damage it.  You can search around for transistor info.  Basically:
12v power--- transistor ----- buzzer
                    Arduino
You send power to the transistor like you would an LED, and it allows 12v power to flow to the buzzer
raron
Or rather:
12v power---resistor---buzzer--- NPN transistor ---GND
                                                           resistor
                                                           Arduino
http://www.kpsec.freeuk.com/trancirc.htm#npn
retrolefty
Or rather:
                                                           resistor
                                                           Arduino
No need for that resistor shown between the buzzer and 12v power, it's a 12volt buzzer.
raron
#7
Mar 30, 2011, 08:19 am Last Edit: Mar 30, 2011, 08:33 am by raron Reason: 1
retrolefty: Ah ok, thanks. The main point was the placement of the NPN transistor though.
12v power---buzzer--- NPN transistor ---GND
                                       resistor
                                        Arduino
retrolefty
Quote
OK, but then it should have included E/B/C information if that was the main point:
12v power---buzzer--- NPN  C > transistor < E ---GND
                                                 B
                                            resistor
                                            Arduino
raron
Quote
There is a little link there for the specially interested. But yeah.
