Topic: switch case newb (Read 332 times) previous topic - next topic
LandonW
never used a switch case statement before   I basically want to increase a PWM value with a button press. however im getting a error.  the example code in the IDE wasn't helpful to me.
Code: [Select]
 if (dimmerPin==LOW);{
    delay(10);
    count++;
      if (count = 4);{
        count = 0;
   switch
    case count = 0
      dimmerVal = 64;
    case count = 1:
      dimmerVal = 128;
    case count = 2:
      dimmerVal = 192;
    case count = 3:
      dimmerVal = 255;
pert
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
DKWatson
Live as if you were to die tomorrow. Learn as if you were to live forever. - Mahatma Gandhi
cattledog
Once you get the switch case syntax correct you won't be doing much switching until you fix these two errors.
Code: [Select]
[code]if (count = 4);{
evanmars
Code: [Select]
And this one
Code: [Select]
LandonW
The correct syntax for switch can be found here.
Thank you,  new code compiles with no errors
LandonW
Code: [Select]
int count;
int dimmerVal;
int ledPin = 0;    //analogWrite
int dimmerPin =3;  //digitalRead
int lightPin = 2;  //analogRead
int auxPin = 4;    // digitalWrite
  pinMode(dimmerPin,INPUT);
  pinMode(lightPin,INPUT);
  pinMode(ledPin,OUTPUT);
  pinMode(auxPin,OUTPUT);
  count = 3;
  if (dimmerPin,LOW);{
    delay(25);
    count++;
      if (count == 4);{
        count = 0;
   switch (count){
    case 0:
      dimmerVal = 0;
    case 1:
      dimmerVal = 85;
    case 2:
      dimmerVal = 170;
    case 3:
      dimmerVal = 255;
DrAzzy
if (dimmerPin,LOW)
No, the comma operator is not what you want there.
I think you meant
if (digitalRead(dimmerPin)==LOW)
You must read the pin, and then check the value you get.
Since LOW is just #defined to 0, you can also do
if(!digitalRead(dimmerPin))
But that's not best practice, as it makes the code a bit less readable for no particular benefit.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
LandonW
if (dimmerPin,LOW)
I think you meant
good call.
RayLivingston
#9
Sep 26, 2018, 01:06 am Last Edit: Sep 26, 2018, 01:07 am by RayLivingston
It may compile without errors, but this is still not going to do what you want it to...
Code: [Select]
Regards,
Ray L.
LandonW
Code: [Select]
Regards,
Ray L.
yes thank you, it has been corrected. sometimes I get in a hurry and forget the little things.
I did grasp the idea of how to set up a switch case, which was my original predicament
PaulS
Did you also note that the ; does NOT belong in that statement?
