Topic: Analogue input Help!!! please!!!!!!! (Read 1 time) previous topic - next topic
poli88
Hi, I have just done a lux meter with a graphical display (KS108) and I want to include a temperature meter into it, but I have no free analogue inputs...
what can  i do? one of the analogue inputs is used for my lux reading (a5) and the rest are taken for the screen.
Kind Regards
Poli
cr0sh
Kind Regards
Poli
Cross-posting won't help your cause...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
TerryKing
Look at DS18B20  .. takes only 1 Digital input.
poli88
I am using that, but as I said I ran out of analogue inputs, I have A5 for the LDR reading and the rest for the GLCD
Regards
robtillaart
ds18b20 doesn't need an analog input. .... Please read the datasheet.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
bilbo
Why are you using analog pins for a glcd?
poli88
because the wireing diagram says so... have you got another wireing diagram that doesnt use analogue input ports?
Regards
poli88
I dont think you can do that tho...
there I am attaching the code I am using...
do you change the pin number definitions in the code like a normal 16x2 lcd or I have to change it from the library I am using? I need help on this please!
Code: [Select]
#include <ks0108.h> //  library for LCD
#include "SystemFont5x7.h"   // we need this for character display, included with ks0108.h download
int LDRPINA5 = 5;
int LDRREADING5;
float Resistance = 10.0;
int val = 0;
GLCD.Init(NON_INVERTED);   // load the GLCD library
GLCD.ClearScreen();
GLCD.SelectFont(System5x7);  // choose font to use (note this needs to match the #include above
  countdown(4);
  GLCD.ClearScreen();
GLCD.DrawRect(0, 0, 127, 63,BLACK);
GLCD.CursorTo(1, 1);
// set cursor to top left of LCD (uses character coordinates
// not pixel coordinates
GLCD.Puts("   Welcome To The"); // sends strings to LCD. Does not wrap to next line!
GLCD.CursorTo(1, 2);
GLCD.Puts("#AMAZING LUX METER#");
GLCD.CursorTo(0, 3);
GLCD.Puts("Project Developed by:");
GLCD.CursorTo(1, 4);
GLCD.Puts("Sixto Llorens Zabala");
GLCD.CursorTo(1, 5);
GLCD.Puts("Student No: 08154978");
delay(900);
GLCD.ClearScreen();
GLCD.Puts("Lux Given in Lumens:"); // sends strings to LCD. Does not wrap to next line!
GLCD.CursorTo(1, 3);
GLCD.Puts("       LUX\t=  ");
void loop(void)
LDRREADING5 = analogRead(5);
float Vout5=(LDRREADING5);
float lux5=((Vout5));
GLCD.CursorTo(12,3);
GLCD.PrintNumber(lux5);
GLCD.ClearScreen();
delay(20);
void countdown(int count){
  while(count--){  // do countdown
    GLCD.CursorTo(10,3);   // first column, second row (offset is from 0)
    GLCD.PutChar(count + '0');
Thanks in advance
