Loading...
Pages: [1]   Go Down
Author Topic: Programming Attiny4313 for use as lcd controller  (Read 974 times)
Offline Offline
Newbie
View Profile
Hello, i signed up onto this forum because i could really use some fresh ideas. Iv been trying to load an LCD and keypad controller program(google: I2C LCD and keypad controller using ATTiny2313) onto an attiny4313 chip i just bought so that i can free up some pins on my Arduino mega 2560(its quite a big project).
I have loaded the Arduino isp program onto the mega and i have the tiny on a breadboard with the VCC, SCK, MISO, MOSI, Reset and GND pins wired correctly.
First of all avrdude is being very unreliable, it wont always make a connection it just gives me this.
Code:
The heartbeat led on the mega then stops and i have to reset and try again. When it finally does respond this happens.
Code:
avrdude: Device signature = 0xffffff
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
If i use the -F overide (providing it actually works again) This happens.
Code:
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.12s
avrdude: Expected signature for ATtiny2313 is 1E 91 0A
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "0xE4"
avrdude: writing lfuse (1 bytes):
Writing |                                                    | 0% 0.00s ***failed;
Writing | ################################################## | 100% 0.33s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xE4:
avrdude: load data lfuse data from input file 0xE4:
avrdude: input file 0xE4 contains 1 bytes
avrdude: reading on-chip lfuse data:
Reading | ################################################## | 100% 0.04s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0xe4 != 0xff
avrdude: verification error; content mismatch
avrdude done.  Thank you.
I also tried skipping the fuse bit and i get a similar error.
Code:
avrdude: reading input file "I2C_LCD.hex"
avrdude: input file I2C_LCD.hex auto detected as Intel Hex
avrdude: writing flash (2036 bytes):
Writing | ################################################## | 100% 5.68s
avrdude: 2036 bytes of flash written
avrdude: verifying flash memory against I2C_LCD.hex:
avrdude: load data flash data from input file I2C_LCD.hex:
avrdude: input file I2C_LCD.hex contains 2036 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 6.19s
         0x12 != 0xff
Dead chip? Anyone got any ideas? Thank you.
Logged
Portugal
Offline Offline
God Member
View Profile
Have you disabled the auto-reset?
If not when you open avrdude it will reset your mega and it wount work, also I dont know if you can use the new Arduinos as ISP's due to the other Atmega that is serving as the USB-serial bridge.
Logged
Offline Offline
Newbie
View Profile
My board isnt actually a proper arduino its based on the older mega but with a 2560 chip, it uses ftdi. I will try what you said about reset.
Logged
Deep south of Italy
Offline Offline
Faraday Member
The quieter you become, the more you can hear
View Profile
i think you are getting errors because of the different device signature, the 4313 signature should be 0x1e 0x92 0x0d
did you changed avrdude.conf?
Logged
Pages: [1]   Go Up
Print
Jump to:
