Topic: Experience with dead-reckoning navigation? (Read 803 times) previous topic - next topic
tim7
Hello,
Has anybody got any experience with gryo and accelerometer sensors?  I'm wondering how fast the errors accumulate when calculating relative-position by dead-reckoning.  For example, if a rover equipped with one of these sensors sets off to do a lap of a room, how near could it get to its starting point after (say) a minute?
cr0sh
I don't have any experience with your parts, but I was recently looking into the issue - which isn't technically "dead reckoning", but more "inertial navigation":
http://en.wikipedia.org/wiki/Inertial_navigation_system
Note the graph at the top - note how poor the accuracy is compared to say, D/GPS...
With that said, I am sure those numbers have to do with actual vehicles (airplanes and/or missles/rockets - most likely) in real-world conditions over large distances. A robot in a room with a perfectly flat floor (and little wheel slipage) would likely fair better. But as soon as you start adding other needs (carpeted floor, irregular surfaces, etc) - navigational accuracy likely goes down quickly...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
tim7
Yes, sorry, I used completely the wrong term.  Inertial positioning is what I should have said.
What I have in mind is double-integrating the 3D acceleration to get position, assuming the sensor does not rotate.  Then I'd like to remove the rotation constraint by incorporating readings from a gyro.
The specs for reasonably-priced sensors seem amazingly good, but of course the errors will grow enormously once integrated over time.  The 650m/hr figure on Wikipedia is discouraging.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
