Topic: Why Arduino writes at most 150-180 entries on SD card? (I need at least 720) (Read 685 times) previous topic - next topic
neotba
Hello there :)
I wanted to create a little weather station lately, it works pretty fine for the moment except one thing.
The setup is Arduino UNO, Ethernet Shield with SD slot, SD card, Barometer, Humiture Sensor, and Photosensor (wires and breadboard :))), I wanted to take readings every minute.
The problem is that Arduino only writes  first 150-180 entries to the card and stops for some reason.
I cannot find the reson, so I ask your help, my friends :)
Here is the code:
Code: [Select]
//for humiture sensor
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
//for barometer
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
//for SD card
#include <SD.h>
#define DHTPIN            2         // Pin which is connected to the DHT sensor (humiture).
#define BMP_SCK 13                  //barometer
#define BMP_MISO 12                 //barometer
#define BMP_MOSI 11                 //barometer
#define BMP_CS 10                   //barometer
File myFile;                        //SD card
const int photocellPin = A0;        //photosensor
int outputValue = 0;                //photosensor
#define DHTTYPE           DHT11     // DHT 11
//for barometer
Adafruit_BMP280 bme(BMP_CS, BMP_MOSI, BMP_MISO,  BMP_SCK);
DHT_Unified dht(DHTPIN, DHTTYPE);
uint32_t delayMS;
  // Initialize HUMITURE device.
  dht.begin();
  sensor_t sensor;
  dht.temperature().getSensor(&sensor);
  dht.humidity().getSensor(&sensor);
  // Set delay between sensor readings based on sensor details.
  //delayMS = sensor.min_delay / 1000;
  delayMS = 60000; //in miliseconds
  //initialize BAROMETER
  if (!bme.begin()) {
    Serial.println("Could not find a valid BMP280 sensor, check wiring!");
    while (1);
  //SD SETUP
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  Serial.print("Humiture sensor values\n");
  Serial.print("************************************\n");
  // Delay between measurements.
  //delay(delayMS);
  // Get temperature event and print its value.
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  if (isnan(event.temperature)) {
    Serial.println("Error reading temperature!");
  else {
    Serial.print("Temperature: ");
    Serial.print(event.temperature - 1);
    Serial.println(" *C");
  // Get humidity event and print its value.
  dht.humidity().getEvent(&event);
  if (isnan(event.relative_humidity)) {
    Serial.println("Error reading humidity!");
  else {
    Serial.print("Humidity: ");
    Serial.print(event.relative_humidity + 20);
    Serial.println("%");
  // BAROMETER
  Serial.print("Barometer values\n");
  Serial.print("Temperature = ");
  Serial.print(bme.readTemperature() - 4.22);
  Serial.print("Pressure = ");
  Serial.print(bme.readPressure()+4339.15);
  Serial.println(" Pa");
  Serial.print("Approx altitude = ");
  Serial.print(bme.readAltitude(1018.00)); // this should be adjusted to your local forcast
  Serial.println(" m");
  //delay(delayMS);
  //PHOTOSENSOR
  Serial.print("Photosensor values\n");
  outputValue = analogRead(photocellPin);
  Serial.print("Brightness = ");
  Serial.println(outputValue);
  Serial.print("_______________________________________\n");
  //SD card
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.print("H_temp = ");
    myFile.print(event.temperature - 1);
    myFile.print(" ");
    myFile.print("H_humi = ");
    myFile.print(event.relative_humidity +22);
    myFile.print(" ");
    myFile.print("B_temp = ");
    myFile.print(bme.readTemperature() - 3);
    myFile.print(" ");
    myFile.print("B_pres = ");
    myFile.print(bme.readPressure() + 4339.15);
    myFile.print(" ");
    myFile.print("B_elev= ");
    myFile.print(bme.readAltitude(1018.00));
    myFile.print(" ");
    myFile.print("P_valu= ");
    myFile.print(outputValue);
    myFile.println(" ");
    // close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  delay(delayMS);
Lucario448
srnet
Quote
Did you get this warning when compliling;
'Low memory available, stability problems may occur'
$50SAT is now Silent (but probably still running)
http://www.50dollarsat.info/
http://www.loratracker.uk/
neotba
How much free RAM is reported after compiling?
Here is the output after the complilation and upload
Code: [Select]
Sketch uses 21862 bytes (8%) of program storage space. Maximum is 253952 bytes.
Global variables use 1482 bytes (18%) of dynamic memory, leaving 6710 bytes for local variables. Maximum is 8192 bytes.
srnet
Code: [Select]
Sketch uses 21862 bytes (8%) of program storage space. [b]Maximum is 253952 bytes[/b].
That suggests your using an ATmega2560, but your first post said;
Quote
Slumpert
Maybe try doubling data written and see if the lockup happens noticeably faster.
