Topic: Help needed with a remotely controlled robot (Read 2070 times) previous topic - next topic
Ayouzef
Hello experts ,
Here is what I am trying to do .. I am controlling 2 dc motors and 2 linear actuators using an Arduino Mega board with an Ethernet shield . The board is then connected to a LINKSYS router (running as bridge) through the ethernet cable . The bridge is bridged to another LINKSYS router which is creating a WIFI network. On the other hand, I am trying to control all this using a joystick connected to a laptop. Therefore , there must be some sort of a software running on the laptop to map the joystick position and send that to the Arduino board through the wireless connection. I am currently using AUTOHOTKEY to map the position of the joystick to a corresponding  keyboard button.
Here is how it works :
1-The AutoHotkey is running a script that will monitor the position of the joystick with respect to X and Y axis, for example it would say something like :
if X>10
  Send (1);
and what is this doing is sending a Ascii code of the digit one every time the condition of (the joystick is pushed to the left 10% before the origin point) x>10% of the total X axis
Similarly ,
if 10>y>20
2- The character is sent to the serial port and received by the Arduino code to do a certain action , for example
if char(inByte == '1')
{digitalwrite MotorPinLeft (High)} ;
Now, my question : Is there any other way of doing the same thing using a different client on the laptop since I am not satisfied with AutoHotKey performance ?
Also, If I want to write a line to check if connection between client and server is lost , how do I do that?
I will post entire code here for more details.. Please feel free to ask question if something isn't clear .. Any help will be appreciated
Thanks
The code:
Lunabot Motor Control
Characters are accepted via telnet connection and interpretted as
motor control Commanda
created 18 Dec 2009
by David A. Mellis
modified 30 Dec 2010
by Bill Bagdon
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = {
  192,168,1, 177 };
byte gateway[] = {
  192,168,1, 254 };
byte subnet[] = {
  255, 255, 0, 0 };
#define MotorPinLeft 9
#define MotorPinRight 6
#define ArmUp 28
#define ArmDown 22
#define BucketUp 25
#define BucketDown 27
// telnet defaults to port 23
Server server(23);
boolean gotAMessage = false; // whether or not you got a message from the client yet
  pinMode(MotorPinLeft, OUTPUT);
  pinMode(MotorPinRight, OUTPUT);
  pinMode(ArmUp, OUTPUT);
  pinMode(ArmDown, OUTPUT);
  pinMode(BucketUp, OUTPUT);
  pinMode(BucketDown, OUTPUT);
  //initialize the ethernet device
  Ethernet.begin(mac, ip, gateway, subnet);
  // start listening for clients
  server.begin();
  // open the serial port
  // wait for a new client:
  Client client = server.available();
  // when the client sends the first byte, say hello:
  if (client) {
    if (!gotAMessage) {
      Serial.println("We have a new client");
      client.println("Welcome");
      gotAMessage = true;
    // read the bytes incoming from the client:
    char inByte = client.read();
    move(inByte);
    // echo the bytes back to the client:
    server.write(inByte);
    // echo the bytes to the server as well:
    Serial.print(inByte);
void move(char inByte){
  if (inByte == 'x'){
    digitalWrite(ArmUp, HIGH);
    digitalWrite(ArmDown, LOW);  //1 0
  else if (inByte == 'v'){
    digitalWrite(ArmUp, LOW);
    digitalWrite(ArmDown, HIGH);  //0 1
  else if (inByte == 'n'){
    digitalWrite(ArmDown, LOW);  // 0 0
else if (inByte == 'c'){
    digitalWrite(BucketUp, HIGH);
    digitalWrite(BucketDown, LOW);  //1 0
  else if (inByte == 'b'){
    digitalWrite(BucketUp, LOW);
    digitalWrite(BucketDown, HIGH);  //0 1
    digitalWrite(BucketDown, LOW);  //0 0
  else if (inByte == '9'){
      analogWrite(MotorPinLeft, 140);    // 1
    else if (inByte == '8'){
      analogWrite(MotorPinLeft, 151);    // 2
    else if (inByte == '7'){
      analogWrite(MotorPinLeft, 162);    // 3
    else if (inByte == '6'){
      analogWrite(MotorPinLeft, 173);    // 4  // CLOCKWISE
    else if (inByte == '5'){
      analogWrite(MotorPinLeft, 188);    // 5  // NEUTRAL
    else if (inByte == '4'){
      analogWrite(MotorPinLeft, 204);    // 6  // COUNTER CLK
    else if (inByte == '3'){
      analogWrite(MotorPinLeft, 215);    // 7
    else if (inByte == '2'){
      analogWrite(MotorPinLeft, 226);    // 8
    else if (inByte == '1'){
      analogWrite(MotorPinLeft, 237);    // 9
    if (inByte == '9'){
      analogWrite(MotorPinRight, 140);    // 1
      analogWrite(MotorPinRight, 151);    // 2
      analogWrite(MotorPinRight, 162);    // 3
      analogWrite(MotorPinRight, 173);    // 4  // CLOCKWISE
      analogWrite(MotorPinRight, 188);    // 5  // NEUTRAL
      analogWrite(MotorPinRight, 204);    // 6  // COUNTER CLK
      analogWrite(MotorPinRight, 215);    // 7
      analogWrite(MotorPinRight, 226);    // 8
      analogWrite(MotorPinRight, 237);    // 9
  if (inByte == 'a'){
    else if (inByte == 's'){
    else if (inByte == 'd'){
    else if (inByte == 'f'){
    else if (inByte == 'g'){
    else if (inByte == 'h'){
    else if (inByte == 'j'){
    else if (inByte == 'k'){
    else if (inByte == 'l'){
    if (inByte == 'l'){
    else if (inByte == 'a'){
Send (a);
AWOL
Ow! My scrolling finger hurts.
When posting code, please use the # (Code) icon on the editor's toolbar.
(Not sure all those "else"s are strictly necessary)
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Ayouzef
Sorry , I am new to forums ! You probably right, all these "elses " aren't  necessary .. I am pretty sure there is a better way to code this.. I just don't know it .. Please let me know if you know it
Thanks
AWOL
Well, you could consider the switch/case construct.
Don't forget to use 'break'.
Though, for that number of actions, I'd probably consider using a simple interpreter and table of characters/pins/actions.
