Loading...
Pages: [1]   Go Down
Author Topic: Can Only Upload Once  (Read 416 times)
NYC
Offline Offline
Full Member
The singularity is near!
View Profile
Steps to reproduce:
Burn a ATMEGA328P-PU with an ArduinoISP - No errors
Download blink sketch - No errors and it blinks
Download blink sketch a second time - Fails with following error:
Burning and downloads from Arduino Development Environment on a Mac. Arduino is breadboard variety like http://itp.nyu.edu/physcomp/Tutorials/ArduinoBreadboard
If the atmega is burned again, a sketch can be downloaded once.
Any ideas for diagnosing this? Is there anything funky about ArduinoISP burning?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Did you set the lock bits after uploading the bootloader?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Which bootloader code are you using. This sounds like on of the Uno bootloader bugs that surfaced a while back. There is a newer version around that solves it, search around. I don't own a Uno so I haven't kept a link.
Lefty
Logged
France
Offline Offline
Sr. Member
View Profile
Lefty, are you thinking of the "amnesia" bug?  This sounds different.
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Is the BOOTRST fuse set?
Don
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Looks like that breadboard does not implement auto-reset.
Connect the Reset pin (Pin 1 of the ATmega) to ground until you see the "Binary sketch size" message in the IDE.
Logged
NYC
Offline Offline
Full Member
View Profile
It was the auto reset issue!
I'm not sure why the first sketch uploads without holding the reset button, but burn and repeated upload worked with 2 atmega328p chips.
Also had to move freshly burned chip to another breadboard (instead of uploading on same board as Arduino ISP), but this is a good idea anyway.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
I'm not sure why the first sketch uploads without holding the reset button.
I think it's because with a fresh bootloader there is no sketch to run so the bootloader just waits for your upload.
Once a sketch has been uploaded the bootloader only gets control for a short time after reset before turning control over to the sketch.  If the upload doesn't start during that window the bootloader won't process it.
Logged
Pages: [1]   Go Up
Print
Jump to:
