Topic: RN-41 bluetooth with an arduino (Read 4341 times) previous topic - next topic
SouthernAtHeart
Is there a tutorial or guide to using the RN-41 (http://www.sparkfun.com/products/8497)with an Uno or other arduino?
The RN-41 only costs $25 at Sparkfun, but the Bluetooth Mate Gold costs $65...  If is just a few components different and the knowhow to hook it up, I can supply the first, but the knowhow?  I've searched quite a bit, but there's just not much out there.  There must be more to it that I don't understand?
frank26080115
RN-41 are easy to use, there's no configuration involved. Just install the drivers, power it up, and it should let you pair with your computer without you actually doing anything to it. Then just wire it up to your Arduino's RX and TX and you are done.
Freelance engineer, consultant, contractor. Graduated from UW in 2013.
SouthernAtHeart
How do you wire it up?  Isn't it 3.3v, and the Uno 5v?  I thought you'd need at least a step up/down regulator.
Here's the schematic off the datasheet.  Could someone post a schematic of the minimum/simplest way to connect this to an Uno?
frank26080115
Just copy the schematic of the Bluetooth Mate Gold if you need level conversion, or run the Arduino at 3.3V
SouthernAtHeart
Trying to understand the schematic, and make the Rn41 work with the Uno.
  In the schematic I've attached from Sparkfun:
The part I've highlighted in BL:  Could that be replaced with the Logic Level Converter from SparkFun (http://www.sparkfun.com/products/8745)
The part highlighted in RD: Is that just a 3.3 volt power supply?  So the Uno has a 3.3 v pin, I could use, correct?
This is starting to all look pretty easy.
...what is the part I've highlight in GR?
And lastly, There are 4 pins being connected, but I thought I'd just need Rx and Tx for a general purpose 'serial pipeline'?  Do I need rts & cts?
frank26080115
SJ is solder jumper
You don't need RTS or CTS
The 3.3V pin on the Uno can be used instead of a dedicated power supply circuit (I think... Only if RN-41 use less than 50 mA), but any version before Uno has a baaaad 3.3V supply from the FTDI chip and I would never use it.
You know what, I'm at work right now, but I have a way simpler way of doing level conversion than SparkFun. Level conversion can be done with a diode and a resistor, instead of the whole mosfet thing they have.
                           ^ 3.3V
                           > 10K resistor
                 diode     |
(Arduino's TX) -----|<|-----+---------- (RN-41's RX)
(Arduino's RX) ------------------------ (RN-41's TX)
use a high speed diode
SouthernAtHeart
Thanks, to make sure I got the diode right, I drew up a quick schematic:
Do I need to ground RTS or CTS? or just leave un connected?
frank26080115
Your diagram looks right
The diode should ideally have a low voltage drop, I forgot to mention that, get a Schottky diode
Leave RTS and CTS unconnected
SouthernAtHeart
Thanks,
the 1N5819 is a Schottky diode, I thought?  I hope so, I've ordered some to use as motor pike shunts on my H bridge.
SouthernAtHeart
What do these numbers mean?  will the RN41 run off the Uno's 3.3 supply?
frank26080115
I actually don't know what the RX and TX supply current actually means, sorry.
The regulator that comes with USnooBie (see my signature below) is the TC1262 and can supply 500 mA worth of 3.3V
SouthernAtHeart
Anyone else know if you can use the Uno's 3.3 v to power the Rn-41; the specs (see my previous post) kinda say 2 different things...
SouthernAtHeart
SJ is solder jumper
                            ^ 3.3V
                            > 10K resistor
                  diode     |
Can I do a similar thing to use the 5V FTDI cable from sparkfun to upload sketch to a 3.3Volt pro mini?
Here's a schematic I drew up:
frank26080115
from http://www.sparkfun.com/products/9716
This board ship default to 5V, but you can cut the default trace and add a solder jumper if you need to switch to 3.3V.
