Loading...
Pages: [1]   Go Down
Author Topic: I have Random function...Songs not playing randomly?  (Read 421 times)
Offline Offline
Newbie
View Profile
Hello there,
I have a code written, I had thought, to play a random song when a HIGH signal is received, but I keep getting the same track played each time (case 3).
Here is the code that I thought would give me randomness:
Code:
byte check_switches()
  if (digitalRead(14) == HIGH)  // check for high signal on pin 14 (analog 0)
       return random(1,6);
  if (wave.isplaying)  // stop it
    wave.stop();
  return 0;
Here is my whole code:
Code:
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the filesystem on the card
FatReader f;      // This holds the information for the file we're play
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
#define DEBOUNCE 100  // button debouncer
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
  extern int  __bss_end;
  extern int  *__brkval;
  int free_memory;
  if((int)__brkval == 0) {
    free_memory = ((int)&free_memory) - ((int)&__bss_end);
  else {
    free_memory = ((int)&free_memory) - ((int)__brkval);
  return free_memory;
void sdErrorCheck(void)
  if (!card.errorCode()) return;
  putstring("\n\rSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  putstring(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
  // set up serial port
  putstring_nl("WaveHC with 6 buttons");
   putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(freeRam());      // if this is under 150 bytes it may spell trouble!
  // Set the output pins for the DAC control. This pins are defined in the library
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // pin13 LED
  pinMode(13, OUTPUT);
  //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
    sdErrorCheck();
    while(1);                            // then 'halt' - do nothing!
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
// Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                             // we found one, lets bail
  if (part == 5) {                       // if we ended up not finding one  :(
    putstring_nl("No valid FAT partition!");
    sdErrorCheck();      // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    putstring_nl("Can't open root dir!"); // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Ready!");
  //putstring(".");            // uncomment this to see if the loop isnt running
  switch (check_switches()) {
    case 1:
      playcomplete("BANJOSNG.WAV");
    case 2:
      playcomplete("LTLMAGGE.WAV");
    case 3:
      playcomplete("OMIEWISE.WAV");
    case 4:
      playcomplete("SAMOLMAN.WAV");
    case 5:
      playcomplete("STRAWFOT.WAV");
    case 6:
      playcomplete("WAYFRSTR.WAV");
       return random(1,6);
    wave.stop();
  return 0;
// Plays a full file from beginning to end with no pause.
void playcomplete(char *name) {
  // call our helper to find and play this name
  playfile(name);
  while (wave.isplaying) {
  // do nothing while its playing
  // now its done playing
void playfile(char *name) {
  // see if the wave object is currently doing something
  if (wave.isplaying) {// already playing something, so stop it!
    wave.stop(); // stop it
  // look in the root directory and open the file
  if (!f.open(root, name)) {
    putstring("Couldn't open file "); Serial.print(name); return;
  // OK read the file and turn it into a wave object
  if (!wave.create(f)) {
    putstring_nl("Not a valid WAV"); return;
  // ok time to play! start playback
  wave.play();
Logged
Offline Offline
Newbie
View Profile
wait wait ah yes randomSeed
Logged
Offline Offline
Newbie
View Profile
where do I pop randomSeed in to make it work?
Thanks in advance!
Logged
Offline Offline
Newbie
View Profile
Thank you!!
Logged
Offline Offline
Newbie
View Profile
So you're saying it's as simple as adding:
Code:
  randomSeed(analogRead(0));
and an antenna?  I have two inches of copper wire now poking out of pin 0.  Now it is playing a different song each time I start it up, which is hopeful, but not random yet.  Am I doing something wrong?  Please forgive me I'm totally new to this.
Cheers!
Logged
Offline Offline
Newbie
View Profile
Sorry I'll be more clear.  Since adding randomSeed, it is playing the same song each time I start it up, however said song is a different song than the one that played every time I started it up before adding randomSeed.
Logged
Offline Offline
Newbie
View Profile
It was playing case 3 on start up before randomSeed, now it is playing case 2 each time.
Logged
Pages: [1]   Go Up
Print
Jump to:
