Loading...
Pages: [1]   Go Down
Author Topic: Servo motors  (Read 1293 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi
Here is a total newbie question.
I am getting totally confused with the jargon surrounding motors.
1)The RC servo community seems to refer to servos as devices that can maintain a particular angle, but not capable of continuous rotation.
But i believe servos such as
http://www.beckhoff.com/english.asp?drive_technology/default.htm, are capable of continuous rotation. So what is a servo??
2)If i want to maintain very precise rpm control(make rpm change as i wish for example like a sine wave), would i use a servo or a DC motor?
3)If i want to maintain a precise angle and change the angle as i desire, would i use a servo?
4)What is the difference between a motor drive and a motor controller?
5)Can i convert a DC/AC motor to a servo using feedback control with pwm signals generated by the Arduino and a suitable motor controller and encoder.
3)Can i control the above Beckhoff servo using an Arduino? Do i need to buy the Drive from them?
Sorry for all the basic questions, but i can't seem to find an answer anywhere. The sales-reps just confuse me with more terminology.
Thanks
Sam
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks, that clears up quite a few issues.
This is what i want to do
1)Build a disk whose rpm varies smoothly(like a sine-wave). It could be shifted by a DC value if the motor can't rotate in the reverse direction.
2)Place the Ardu-imu on this disk and log the rotation angle as measured by the encoder and as measured by the imu.
This way i will know how accurate the Ardu-imu is.
I don't need high rpm's.
60 would probably be the peak rpm.
To do this should i buy a "servo" motor like Beckhoff or a plain vanilla DC motor and try to control it's speed using pwm's from the Arduino and a motor controller?
Regds
Sam
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
If you could go as low as 45, an old-fashioned record deck could be a cheap alternative.
(A really old one could do 33, 45 and 78!)
« Last Edit: March 31, 2011, 02:55:02 pm by AWOL » Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi
@KE7GKP
Why do you say, that the test system has lower reliability than the Ardu-IMU?
Shouldn't the accuracy of the test system be determined by the least count of the encoder?
I want to also modify some of the code on the IMU and check the results, to see if it gives a more accurate result.
Won't a stepper motor have backlash error?
@AWOL
Unfortunately i threw away my record player about 3 yrs ago. So how do i achieve such low rpm's
Thanks
Sam
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
Your description of the test method seems open-loop. There was no explanation of how to correlate the Ardu-IMU data with the turntable position / speed / orientation.  For that matter, how do you even know the instantaneous information about the turntable?  And how do you get the data from a spinning Ardu-IMU?
Sorry for not being clearer.
I have an Xbee shield that will sit on the Ardu-imu on the rotating disk, that will act as the transmitter.
Another Arduino will sit on the ground with an Xbee shield(reciever) and a Datalogger shield.
This stationary Arduino will log the encoder signal and the Ardu-imu data with time-stamps. This way i will have correlation between rpm of the rotating disk and the imu data.
Therefore as long as my encoder is accurate, i can treat it as a benchmark to evaluate the imu.
Thanks
Sam
Logged
Georgia, US
Offline Offline
Sr. Member
Arduino makes my head hurt :(
View Profile
Just a minor correction: A motor drive is a electronic system that controls the speed and direction of a motor (as well as numerous other things)
I assume that a motor controller is the exact same thing, just a different term for it.
Logged
Pages: [1]   Go Up
Print
Jump to:
