Loading...
Pages: [1]   Go Down
Author Topic: Help me please  (Read 506 times)
Offline Offline
Newbie
View Profile
Hi everyone
I am using a Arduino Duemilanove and a Ultrasonic ranger to hold the altitude of an Quad-copter. I can use transmitter's switch to switch between altitude hold mode and manual throttle control mode. Once I switch to altitude mode, the Arduino will send a pwm to throttle dut to the range to the ground.  It is working only when it connected to my computer.  If it is not connect to computer, the manual control mode is good. If I switch to altitude hold mode, the motor will be out of control. Is there any problem in the software?
Test video:
The test video just show you how it works. The arduino has been connected to the computer. So it works well.
here is my software:
#include <Servo.h>
Servo myservo;
const int echo = 12;
const int trig = 13;
const int sw = 3;
const int th = 4;
  pinMode(echo,INPUT);
  pinMode(trig,OUTPUT);
  int sensorValue = digitalRead(echo);
  int swValue = digitalRead(sw);
  int thValue = digitalRead(th);
  myservo.attach(9);
  long duration, hold ,power;
  hold = pulseIn(sw,HIGH);
  if (hold>1500)
  digitalWrite(trig,LOW);
  delayMicroseconds(2);
  digitalWrite(trig,HIGH);
  delayMicroseconds(12);
  duration = pulseIn(echo,HIGH);
  duration = map(duration, 0, 1000, 135, 45);
  myservo.write(duration);
 else {
   power = pulseIn(th,HIGH);
   power = map (power, 1000, 2000, 135, 45);
   myservo.write(power);
   delay(15);
« Last Edit: March 31, 2011, 12:52:03 pm by zeran » Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Why do you do this:
Code:
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
I think the ultrasonic sensor does not work, when I pull out the USB.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Maybe you don't have enough current to power it.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
I agree, software should not change because of being powered via external power Vs USB power. It would be helpful if we could see a drawing of at least the power wiring between all the system components.
Lefty
Logged
0
Offline Offline
Sr. Member
what?
View Profile
Hello, Have you considered how wind will change the result, have you thought about using GPS instead, just a thought
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
Quote
It would have to be differential GPS, I think.
Logged
London, England
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
I don't think exact position matters, so long as it doesn't fly into the ground. As for flying into anything else, GPS would not likely help much there either.
Logged
Pages: [1]   Go Up
Print
Jump to:
