Topic: Error compiling blink to MKRZero (Read 1 time) previous topic - next topic
ryan_pelo
I just bought a MKRZero which arrived today. I installed the necessary board from the boards manager. My board gets recognized, but when compiling the sketch I get this error that I've been trying to fix for hours:
Code: [Select]
In file included from C:\Users\ryanh\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/samd21/include/samd21.h:69:0,
                 from C:\Users\ryanh\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/samd.h:105,
                 from C:\Users\ryanh\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/sam.h:470,
                 from C:\Users\ryanh\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.19\cores\arduino/Arduino.h:48,
                 from C:\Users\ryanh\AppData\Local\Temp\arduino_build_369469\sketch\Blink.ino.cpp:1:
C:\Users\ryanh\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0/CMSIS/Device/ATMEL/samd21/include/samd21g18a.h:237:26: fatal error: core_cm0plus.h: No such file or directory
 #include <core_cm0plus.h>
compilation terminated.
exit status 1
Error compiling for board Arduino MKRZERO.
I tried removing and reinstalling the board more than once, with my antivirus software turned off. Still no luck. I've seen a few other posts with this same problem but none of them have been solved, just a few suggestions thrown around (which I tried). Does anyone have any suggestions?
ballscrewbob
Good suggestion is to maybe take a good look around the forum first than you could have asked in the correct section ;)
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
ballscrewbob
Which windows are you on ?
Also turn on VERBOSE for COMPILE in preferences.
I dont see those types of message here on win 7 in IDE 1.8.6 so lets know what you are using ?
With verbose you should see a whole lot more.
BTW just turning off your AV may not completely turn it off !
Last time I saw that error in here it did turn out to overly aggressive AV and adding the Arduino locations to the AV exclusions list fixed it.
SEE HERE
ryan_pelo
Sorry for the late response. I am using arduino 1.8.7 and I'm running windows version 10.0.17134 Build 17134. Just whitelisted the three folders suggested except for the last one. C:\Users\yourname\AppData\Roaming\Arduino15 does not exist for me. what now?
ryan_pelo
I tried installing the core again and I got the same message
ballscrewbob
The last one may be a HIDDEN folder so you should enable the "show hidden folders" option to see it.
ryan_pelo
Hidden is turned on. I have the roaming folder, but no arduino folder within it
ballscrewbob
#7
Oct 06, 2018, 01:05 pm Last Edit: Oct 06, 2018, 01:07 pm by ballscrewbob
Unless you have an odd installation of windows or the IDE it should be there.
Which IDE are you using ?
ryan_pelo
I used the installer for 1.8.7. The only thing I could think of is it might be in the admin's directory (which I don't have access to) but I have no idea how that would happen or how probable it is. Does this mean I need to uninstall and reinstall arduino?
ballscrewbob
#9
Oct 07, 2018, 01:26 pm Last Edit: Oct 07, 2018, 01:26 pm by ballscrewbob
I dont think chasing the folder will matter too much as you found the others and I realised that sometimes its just two out of three (my bad).
A re-install may help and is not hard to do.
There is a help file for that attached.
