Topic: Missing Simulink Support for Arduino MKR Motor Carrier and Arduino Sensors (Read 3282 times) previous topic - next topic
sahil6888
Hello,
I have successfully installed the Arduino Engineering kit toolbox and the MKR Motor Carrier library. I have been able to execute code and simulink simulations up to Section 2.3.2 of the engineering kit tutorial without any problems. However for section 2.3.2.1, it appears that two toolboxes are missing from my library:
- Simulink Support for Arduino MKR Motor Carrier
- Simulink Support for Arduino Sensors
I have installed and can see the 'Simulink Support Package for Arduino Hardware' in my libraries browser. I would greatly appreciate some help in locating or install the aforementioned missing packages.
Thanks and regards,
Sahil Girish
Sravya Amirisetti
Hello Sahil,
Apparently,there was a bug in Arduino Engineering Kit Hardware Support 18b add-on which was updated on 4th October version 1.1.1.
I request you to uninstall and reinstall the Arduino Engineering kit Hardware support18b add-on.
Thank you!
Best Regards,
Sravya.
haklid
I still suffer from exactly the same problem, even though having most recent addons and libraries installed. Can someone actually confirm that it works?
Thanks
MadhuGovindarajan
Simulink Support for Arduino Sensors has now moved inside the Simulink Support package for Arduino itself.
If your library browser does not show the Simulink support for MKR Motor Carrier library after installing the latest version of support, please refresh the library browser. To do this, right click inside the library browser and select refresh.
