I am working with a max7219 that controls a 5x7 led matrix with the pattern library i found here;
http://www.stefanomanni.it/arduino/wp-content/uploads/2009/03/text-scrolling-with-a-5c3977-led-matrix.zipIt is a library of patterns called in the arduino code to scroll letter numbers etc.
I am also using the DHT22 temp and humidity sensor with its own library to get readings.
I want to scroll these reading on the led matrix but have run into a problem.
the function to scroll text uses a string of declared characters to call each pattern. this is fine when scrolling text,
scrollString("TEXT")
but not if i want to scroll the reading from the sensor,
scrollString(myDHT22.getTemperatureC())
i end up with invalid conversion from int to char
is there any way i could get the sensor readings to work with this pattern library?
here is my code
/* 29 mar 09 */
/* Text scrolling with a 5x7 led matrix.
/* ATTENTION: Copy Pattern.h file in ./hardware/libraries/Pattern/ directory */
#include <DHT22.h>
#include <avr/pgmspace.h>
#include <Pattern.h>
#define DHT22_PIN 7
#define DELAY 75
// Setup a DHT22 instance
DHT22 myDHT22(DHT22_PIN);
int dataIn = 2;
int load = 4;
int clock = 3;
int matrix[7][5]={{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},{0,0,0,0,0},};
int e = 0; // just a varialble
// define max7219 registers
byte max7219_reg_noop = 0x00;
byte max7219_reg_digit0 = 0x01;
byte max7219_reg_digit1 = 0x02;
byte max7219_reg_digit2 = 0x03;
byte max7219_reg_digit3 = 0x04;
byte max7219_reg_digit4 = 0x05;
byte max7219_reg_digit5 = 0x06;
byte max7219_reg_digit6 = 0x07;
byte max7219_reg_digit7 = 0x08;
byte max7219_reg_decodeMode = 0x09;
byte max7219_reg_intensity = 0x0a;
byte max7219_reg_scanLimit = 0x0b;
byte max7219_reg_shutdown = 0x0c;
byte max7219_reg_displayTest = 0x0f;
void putByte(byte data) {
byte i = 8;
byte mask;
while(i > 0) {
mask = 0x01 << (i - 1); // get bitmask
digitalWrite( clock, LOW); // tick
if (data & mask){ // choose bit
digitalWrite(dataIn, HIGH);// send 1
}else{
digitalWrite(dataIn, LOW); // send 0
digitalWrite(clock, HIGH); // tock
--i; // move to lesser bit
void sendToMax( byte reg, byte value) {
digitalWrite(load, LOW); // begin
putByte(reg); // specify register
putByte(value);
digitalWrite(load, LOW); // and load da shit
digitalWrite(load,HIGH);
void setup () {
//wired up to max7219
pinMode(dataIn, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(load, OUTPUT);
//initiation of the max 7219
sendToMax(max7219_reg_decodeMode, 0x00); // not using digits
sendToMax(max7219_reg_scanLimit, 0x06); //scan rows 1 2 3 4 5 6 7
sendToMax(max7219_reg_shutdown, 0x01); // not in shutdown mode
sendToMax(max7219_reg_displayTest, 0x00); // no display test
sendToMax(max7219_reg_intensity, 0xf); // range: 0x00 to 0x0f
for (e=1; e<=7; e++) { // empty registers, turn all LEDs off
sendToMax(e,0);
//I don't know why pow function doesn't work correctly.
//So i prefer to write my personal version of this.
int power(int base, int ex){
int i=1;
int tot=1;
if(i==0) return(1);
else{
while(i<=ex){
tot=tot*base;
i++;
return(tot);
void lightOn(){
int i,j,k;
//light on matrix
for(i=0;i<7;i++){
k=0;
for(j=0;j<5;j++){
if(matrix[i][j]==1) k=k+power(2,j);
sendToMax(i+1,k);
void scrollChar(const int pattern[7][5]){
int i,j,k=0;
while(k<5) //column of pattern
//shift rigidly columns from right to left
for(j=0;j<4;j++){ //column
for(i=0;i<7;i++){ //row
matrix[i][j]= matrix[i][j+1];
//queue k-th column of pattern
matrix[i][4]=pgm_read_byte(&((pattern)[i][k]));
lightOn();
delay(DELAY);
k++;
}//end while
insertSpace();
//insert a space (two column filled with zeros) beetween two chars
void insertSpace(){
int i,j,k=0;
while(k<2) //queue two column of zero
//queue two column filled with zeros
matrix[i][4]=0;
lightOn();
delay(DELAY);
k++;
}//end while
void scrollString(char * s){
int i=0;
while (s[i])
//symbols and letters
if(s[i]=='*')
scrollChar(PATTERN_ELLIP);
if(s[i]=='.')
scrollChar(PATTERN_PERIOD);
if(s[i]=='=')
scrollChar(PATTERN_HEART);
if(s[i]=='!')
scrollChar(PATTERN_EXCLAMATION);
if(s[i]=='%')
scrollChar(PATTERN_PERCENT);
if(s[i]==' ')
scrollChar(PATTERN_BLANK);
if(s[i]=='A')
scrollChar(PATTERN_A);
if(s[i]=='B')
scrollChar(PATTERN_B);
if(s[i]=='C')
scrollChar(PATTERN_C);
if(s[i]=='D')
scrollChar(PATTERN_D);
if(s[i]=='E')
scrollChar(PATTERN_E);
if(s[i]=='F')
scrollChar(PATTERN_F);
if(s[i]=='G')
scrollChar(PATTERN_G);
if(s[i]=='H')
scrollChar(PATTERN_H);
if(s[i]=='I')
scrollChar(PATTERN_I);
if(s[i]=='J')
scrollChar(PATTERN_J);
if(s[i]=='K')
scrollChar(PATTERN_K);
if(s[i]=='L')
scrollChar(PATTERN_L);
if(s[i]=='M')
scrollChar(PATTERN_M);
if(s[i]=='N')
scrollChar(PATTERN_N);
if(s[i]=='O')
scrollChar(PATTERN_O);
if(s[i]=='P')
scrollChar(PATTERN_P);
if(s[i]=='Q')
scrollChar(PATTERN_Q);
if(s[i]=='R')
scrollChar(PATTERN_R);
if(s[i]=='S')
scrollChar(PATTERN_S);
if(s[i]=='T')
scrollChar(PATTERN_T);
if(s[i]=='U')
scrollChar(PATTERN_U);
if(s[i]=='V')
scrollChar(PATTERN_V);
if(s[i]=='W')
scrollChar(PATTERN_W);
if(s[i]=='X')
scrollChar(PATTERN_X);
if(s[i]=='Y')
scrollChar(PATTERN_Y);
if(s[i]=='Z')
scrollChar(PATTERN_Z);
//numbers
if(s[i]=='1')
scrollChar(PATTERN_1);
if(s[i]=='2')
scrollChar(PATTERN_2);
if(s[i]=='3')
scrollChar(PATTERN_3);
if(s[i]=='4')
scrollChar(PATTERN_4);
if(s[i]=='5')
scrollChar(PATTERN_5);
if(s[i]=='6')
scrollChar(PATTERN_6);
if(s[i]=='7')
scrollChar(PATTERN_7);
if(s[i]=='8')
scrollChar(PATTERN_8);
if(s[i]=='9')
scrollChar(PATTERN_9);
if(s[i]=='0')
scrollChar(PATTERN_0);
i++;
}//end while
void loop () {
DHT22_ERROR_t errorCode; // in this loop, the sensor gets readings
// and ideally plugs them into the scroll function
delay(5000);
errorCode = myDHT22.readData();
switch(errorCode)
case DHT_ERROR_NONE:
scrollString("TEMP : ");
delay(500)
delay(500)
scrollString("F ");
delay(500)
scrollString("HUMID : ");
delay(500)
scrollString(myDHT22.getHumidity());
delay(500)
scrollString("%");
case DHT_ERROR_TOOQUICK:
scrollString("TOO QUICK ");
case DHT_ERROR_NOT_PRESENT:
scrollString("NOT PRESENT");
